Washer not letting water in but work as if water was in, drum still spinning, is it cheaper to get a new one or try and get it fixed, any one help
  • 6,784 Answers
Due to the economy and the inflated repair and labor charges that may occur, i recommend purchasing a new washer. the new purchase will be cheaper than this repair.
Posted on Mar 11, 2009
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
Jun 04, 2014 | GE Spacemaker WSLP1100D Top Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Rattling sound during spinning
is it pretty new?
new washers have some sort of metalbar...thatkeeps the drum from spining.....
and has to be removed before operating..first time...
May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Washer won't drain nor spin
Cheaper now, or in the long run?
Many new washers are High efficiency ones. They use less water, less detergent, and less power (washing AND drying). Your situation sounds like a problem with the evacuation pump and/or timer.
Do some research... may even pay to ask a cheap premium question here to get your solution, and see if it is cost effective.
Jan 12, 2009 | Washing Machines
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washer spin problem
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Feb 12, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washer spin when in wash cycle
the problem is specifically the motor tacho which consists of a rotating magnet screwed to the motor shaft and a fixed coil around the magnet. the problem can be the magnet unscrewed or the coil fallen out.either way, they can usually be repaired by glue or packing.
Nov 07, 2006 | Zanussi FJ1454W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
