Question about Invoca Televison & Video
Invoca charger power supply
I need the voltage and polarity for replacement power supply
I believe it is:
12 VDC 500 mA - --> C *- -- + = poor attempt to show the center post os positive and the external sleeve is negative.
Posted on Nov 26, 2013
Need a charger for a Kawasaki power wheels 4 wheeler model: new ninja. What kind do i need for a charger 12 volt for this?
I suggest you refer to the instructions for the specification.
The first requirement is fitting the charger socket and the next is having the correct polarity.
The type of battery is important and the required charge rate/time is also important. A lead/acid battery should ideally use a constant voltage charger. Ni-cads and similar should ideally use a constant current charger.
The vehicle might have it's own intelligent charging circuitry and just need a power supply but if this is not so then the more sophisticated the charger you buy, the longer life the batteries will have.
Apr 29, 2016 | kawasaki Toys
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power voltage for the x235 got display model dosent have a power lead
There should be information about that cast into the outside of the display housing, Charlie, or it may be printed in insanely small print on the serial number label. Most likely, though, it'll be cast into the housing near the power jack. It'll also indicate polarity, but it won't tell you which size the power plug needs to be.
If you can't find the voltage & current requirements anywhere but you CAN find the little polarity indicator, you could buy a "universal" power supply with switchable voltage and polarity. Start with the power supply set to the correct polarity and the LOWEST voltage. If it doesn't work, step up one notch and try again. Increase voltage ONLY until the unit functions, and NO higher. Tape over the voltage selector switch when you have it right.
Aug 04, 2014 | Exercise & Fitness
So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help...
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Computers & Internet
I found an Astar portable dvd player with only the battery charger attached months ago and nobody claimed it. I used it night before last and watched a whole movie, last night I watched a movie and it just...
Possibly you just need a new power supply/battery charger. There is nothing "magic" about the original power supply. Take the player into an electronics supply shop. They should be able to look at it and match
Voltage In Voltage Out Power requirement (milliWatts or Watts) Connector Type Polarity (center of plug positive or negative)
Oct 10, 2009 | Astar PD-3010 Portable DVD Player
Ineed the voltage and connector polarity for the ADS TV ELite Pro
I just found one too, same situation... no power supply. Mine has box and all. On the back of the box, it reads:
Power Supply 7.5 VDC power adapter
It doesn't say what polarity, but judging from the board... I'm gonna' say + in the center. That's what I'm gonna do.
May 31, 2009 | A D S TV Elite Pro/w Remote (TEP-100R)
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Charger
next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
Dec 27, 2008 | Universal Battery Charger Charges Multiple...
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Televison & Video Logo
43 people viewed this question
Top Invoca Televison & Video Experts
Electro Med Services...
Tom Chichester
Are you an Invoca Televison and Video Expert? Answer questions, earn points and help others
