Question about Electrolux Refrigerators
Electrolux water dispenser wont shut off
Water dispenser wont shut off
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 32 Answers
If your water dispenser will not shut off then it is either the dispenser microswitch or the water inlet valve in the back of the refrigerator. Here is link that might help http://apcoappliancerepair.wordpress.com/?s=water+dispenser . Would need a model and serial number to assist you more. Good Luck From Apco Appliance and Air .
Posted on Apr 19, 2013
4 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Aug 17, 2009
  • 884 Answers
SOURCE: water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Posted on Apr 22, 2012
Sea Breeze
  • 4655 Answers
SOURCE: Electrolux fridge water dispenser won't shut off
Then I would assume that the micro switch that you press for water is defective and sticking. I am placing a=> 242100001 Dispenser Module to give you an idea to what I am talking about but if you have a model number for your Electrolux refrigerator I may could find a micro-switch that is replaceable, Thanks Sea Breeze
Posted on Aug 23, 2012
EIFLW55HIWO Electrolux Washer why would water still be in the soap dispenser after washing a load of clothes
I appreciate your post, friend!
Based off the information you have provided you still have water inside of the dispenser of your Electrolux washer. This is a normal operation of your washer. This is due to the siphoning action of your dispenser and washer. You may need to empty the dispenser every once in a while due to the water left inside of it. I hope this information is helpful. -Matt
Feb 25, 2015 | Electrolux Washing Machines
Why does my Electrolux #EWFLW65HIW have water left in soap dispenser
Good Afternoon Friend,
I understand that your Electrolux washer, model# EWFLW65HIW, has water left in the soap dispenser. This is typical for your particular model. The soap and fabric softener area are set up on what is called a siphoning system. This means that when it is time for the soap to release it will release and run water through the area. If the mechanism closes before the water is done running through, you can have water left in the soap dispenser. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Electrolux Washing Machines
Hi there.Got any tips on my fridge making ice but not despensing it through the door it is dead not a sound.However it is putting out water. thanks
I understand that the dispenser, on your Electrolux refrigerator, is dispensing water but not ice. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try to get ice out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number, so I am able to better assist. Hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Electrolux Refrigerators
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
Aug 23, 2012 | Electrolux Refrigerators
Electrolux water dispensor won't shut off
hi.this sounds like either your valve is jammed open or micro switch on dispenser. (turn water off)good luck ali
Jul 06, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The panel for the ice machine and water dispenser has shut off.
I have had the same probelm for over a year. It appears to be a problem in the touch pad w/ribbon connector which Electrolux refuse to accept responsibility for a faulty product. Model E230575DSS8
Apr 20, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Ice dispenser has black mold around area that ice comes out
shut down unit press for ice the door will open wipe with warm water
Apr 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerators Logo
808 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
