Question about Panasonic Televison & Video
Can I convert this tv to a digital converter? It has no external connections except for the electric plug. I use for camping and for emergency power loss. Thank you for your help.
  • 1 more comment
  • antone4228 Mar 12, 2009
    Hi pph_pa_guy, thanks for your response. My TV is a Panasonic Model TR 5046P AC/DC Battery DC 9.6V 6W.
  • antone4228 Mar 13, 2009
    pgh_pa_guy
    Thanks for your help. I finally have the information and proceedure to solve my inquery. You are the best!
  • May 11, 2010
    What make and model TV is this?
    President:
  • 2,992 Answers
I was hoping I'd be able to find a manual or service info in my files once I knew the model, but no luck. So I don't know for sure on your TV, but almost every set Panasonic made had an external antenna connection. They usually used a mini jack, normally on the rear or one of the side panels. If you find a connection on your set, just pick up the appropriate adapter from Radio Shack. (The plug on an antenna cable is called an F-connector, so you can fling about tech terms.)
If this set truly has no external antenna connector, you can still hook a converter box to the set. Get a 75-ohm to 300-ohm converter (also called a balun). This has the threaded F-connector on one end and a length of flat two conductor antenna cable with terminals at the other end. Simply use an alligator clip jumper wire to clip one of the terminals to the TV's built-in rod antenna and turn the set to channel 3 or 4 for the converter box signal.
The bigger problem you might have is if you use this set without an AC power source. I haven't yet seen a converter box that allows you to use a DC power source. They all have built-in supplies and need AC. It might be possible to add a DC input jack to a converter, but I've never tried it.
Hope I've been able to help you. Thanks for asking here!
Posted on Mar 13, 2009
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
Trying to hook up to digital converter box and cannot get the tv to see it? It won't let me in to set channels.
Check ur tv converter box a small button on the back of the converter box make sure it is not set to channel 4,make sure it set it to channel 3.Put ur tv on channel 3.Take the antena signal input put it in the converter box hole that call ANT.Take the wire that came with the converter box put the wire one side of it connected to the other hole into the converter that said OutPut.The other side of the wire should be connected to the hole in the tv said ANT hole.Now make sure ur tv converter box power a/c cord plug into the a/c power outlet and the power button is press on and have power to the converter box.The converter box now power LED light on indication should be on and it is green.Now the tv CRT screen picture should have a menu of the converter box funsctions.Just follow the on screen instructions and press the enter button on the remote and it will now auto scan for those free air Digital DTV channels.When the auto scan it reaches 100% is it done.Now u have done it.
Nov 12, 2010 | Curtis-Mathis Televison & Video
I have no audio output from the tv except a digital audio output. Can I connect that to the surround system? There is also no sound from any other input, radio, cd player etc.
lstiff,
You don't say what system that you need the audio to be sent to so I will presume that the system of choice at least has composite inputs (red and white).
If where the audio from your tv is going does not have a digital coaxial input, the digital coaxial output from the tv can be converted using a external purchased converter online; they relatively cheap items.
The easiest way is to just use the composite wires as most likely all of your units have these inputs and outputs.
-Chris
Feb 27, 2010 | Bose Lifestyle 12 System
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
WeatherX Portable TV and the Digital Signal --- HELP
I haven't done this, but did find information that might help.
Watch A Battery TV With A Converter Box
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
Jun 12, 2009 | Casio TV-880 2.3 in. Handheld Television
HANDHELD UNIT NEED ADAPTER TO GET DIGITAL SIGNAL NEAR KCMO
To connect a converter box to a handheld TV that has an external antenna jack, you need an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 12, 2009 | Casio TV-980 2.3 in. Handheld Television
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
I have old tv with rf connection need to adapt to rca plugs
Simply insert the converter between the curent cable and the TV. The converter should have come with a short RF cable that you can use between teh converter and the TV. I have incluede a before and after line diagran below.
Dan
BEFORE: cable==> TV
AFTER: Cable==> converter ==>TV
Feb 25, 2009 | Insignia Digital-to-Analog Converter for...
Hand held casio tv vs digital signal
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Apr 29, 2008 | Televison & Video
Televison & Video Logo
290 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
