Question about Crown XTi 4000 Amplifier
Amp will not power up - Crown XTi 4000 Amplifier
Cartridge is not recognize, it states that my cartridge is not installed properly, i already tried to removed it and reinstall it but always the same result.. help pls
1. Switch off the printer (the button Power ).
2. Holding button Resume , include the printer (press the button Power ).
3. Holding button Power , release button Resume (indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here).
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake).
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times contract.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6:
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant of the unset)
Sep 30, 2009 | Canon PIXMA iP1300 Printer
Canon doc 203 both light blinking
or
Sep 30, 2009 | Canon Office Equipment & Supplies
I cant print with my canon ip1300 printer? why?
or
Sep 28, 2009 | Office Equipment & Supplies
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Nissan maxima 1996
moz-screenshot.png#1-10 amp
SRS (Aribag)
#2-15 Amp
Air conditioner
#3-15 Amp
Air Conditioner
#4-7.5 Amp
A/T TP/Sw
#5-Tail LIght, Turn Signal Switch
#6-15 Amp
Horn
#7-10 Amp
Power Mirror, Mirror Heaters
#8-10 Amp
#9-10 Amp
#10-15 Amp
Power Windows
#11-10 Amp
Turn Signal
#12-7.5 Amp
Power Windo, Door Locks, Sunroof, Time control unit
#13-10 Amp
Meter, ABS, ASCD, Back-up Lights, Air bag, Warning Chime
#14-7.5 Amp
Corner, Turn
#15-10 Amp
ABS
#16-7.5 Amp
#17-10 Amp
A/C, Fuel Pump, Canister, EGR, Cooling Fan, ASCD
#18-7.5 Amp
Illumination
#19-7.5 Amp
Wiper Motor
#20-20 Amp
Wiper washer timer
#21-10 Amp
Horn, Audio, Power Antenna
#22-15 Amp
Audio
#23-10 Amp
#24-10 Amp
#25-15 Amp
#26-7.5 Amp
Step/L, Room
#27-10 Amp
#28-7.5 Amp
#29-7.5 Amp
Heated Seats
#30-20 Amp
A/C
#31-10 Amp
#32-15 Amp
Fuel Pump
#33-10 Amp
Theft Warning System
#34-10 Amp
Fuel, RO2H
#35-15 Amp
#36-7.5 Amp
#37-10 Amp
TLID, MULTI
#38-7.5 Amp
Rear Defogger
#39-7.5 Amp
Rear Defogger
#40-20 Amp
Door Lock, Horn, Multi, SRS, Power Antenna, Timer
Aug 01, 2009 | 1996 Nissan Maxima
Canon MP830 HAVE A ERROR CODE 6A00 WE HAVE INK PROBLEM CUZ IT DOES'T RUNINIG
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
2. Holding button Resume (the red triangle in кружочке), include the printer (press the button Power ) - an indicator fires the green colour.
3. Holding button Power , release the button Resume .
4. Not releasing button Power , two times press the button Resume and release both buttons.
5. After indicator of the cut-in/readiness поморгает and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-orange.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter ща pampers). For switching off the printer button Power press once again.
Jul 21, 2009 | Canon Office Equipment & Supplies
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 02, 2009 | 2004 Dodge Intrepid
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Flashing lights
3. Holding button Power , release the button Resume (the indicator of the feeding/readiness must glow green)
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (the indicator of the feeding/readiness green, indicator mistake yellow)
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press else raz.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times podryad.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6 :
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press else raz.
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant sb
Apr 02, 2008 | Office Equipment & Supplies
Crown XTi 4000 Amplifier Logo
93 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
