Question about ASUS Intel 810 Chipset MEW-AM Motherboard
Manual for motherboard k2-gl6e - ASUS Intel 810 Chipset MEW-AM Motherboard
Cant log in
If you can't log into your gmail, due to incorrect password, or username, got here: Having trouble signing in. This will allow you the recover and reset the password.
Feb 04, 2015 | HP 5188-1749 Compaq Motherboard Gamilla2...
Need motherboard compaq SR1630NX
This is a ASUS A8AE-LE, HP/Compaq ref: AmberineM-GL6E, HP part number 5188-2526
Jan 24, 2013 | HP Compaq Presario SR1630NX PC Desktop
I am having trouble with the hard drive hanging while booting up Ubuntu 10.10 from a Maxtor DiamondMax 16 hard drive (4R160L0) attached to the primary IDE port on a K2-GL6E Compaq mother board. The drive...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 11, 2011 | Compaq (203966-001) Motherboard
Cuantos es maximo de memoria para una compac presario300+
Debes checar ud. el modelo de motherboard. Si es Salmon-GL6E, el maximo es 2GB.
Mire aqui.
Suerte
Jan 18, 2011 | Compaq Presario SR1475CL Athlon64 3400+...
Hello respected person, i need free download VGA driver for K2-GL6E. this is a compaq presario 5056 desktop motherboard. Pls. help me.
Compaq Presario 5056 Drivers
Please visit the above link from Official HP Compaq Support and download the drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Computers & Internet
Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Aug 11, 2009 | ASUS Intel 5000P Chipset...
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
Motherboard
Try adding and removing hardware from the HP website:
Or look up the mother board on ther ASUS  website: ASUS CUW-AM
HP/Compaq name: Amberine-GL6E
http://support.asus.com/download/download.aspx?SLanguage=en-us
http://h10025.www1.hp.com/ewfrf/wc/product?product=81921&lc=en&cc=us&dlc=en&submit.y=3&submit.x=4〈=en&cc=us
Jan 24, 2009 | HP Refurbished MOTHERBOARD (SYSTEM BOARD)...
Installing a k2-gl6e, or trying..
K2GL6E SUPORT AUDIO DRIVER NAME
Jan 27, 2008 | Computers & Internet
ASUS Intel 810 Chipset MEW-AM Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
