Question about Ampeg BA112 1x12' Bass Combo Amplifier
Ba112 Blown fuse
My Yamaha electric piano, P80, will not power up
first - check the power supply if it's really giving power.
Get voltmeter or plug it to something else you know it's working.
If you are sure it does and still nothing, you need to check the fuse inside the P80. I've been there, it's not so hard to open it
(from below of course)
BTW, it's advisable to user surge protector on such delicate devices like computers and keyboards if there are any fuses that have blown. I can't tell you how many times a blown fuse has stopped equipment from working. I had a blown fuse go in a microwave oven a few years back. I called a repair guy while on a job to fix my Leslie (many years ago) and the culprit, a blown fuse. I could have fied it myself if I had given it more thought.
Check the internal fuses first and you might save some money and a trip to a repair center. , sometimes a fuse can look good even when it is blown. If you have a voltage tester do a continuity check on the fuse just to be certain.It's possible that the P80 does not use internal fuses especially since it uses an external 12 volt power pack There might be info on the fuse in the P80 manual. Otherwise try Yamaha support. A lot of low volage gear run of AC adaptors is unfused.
Another possibility is that the power connector or switch on the P80 is broken. DC power jacks are liable to get broken solder joints due to movement, especially if they are circuit board mounted and not chassis mounted. If you know what you are doing test the connector and switch with a multimeter.
If they are good then also check the wires from the switch to the main board. They a probably connected with a plug, which itself can come lose.
You can test for bad connections with the power off. Only test with the power on if you really do know what you are doing! You won't electrocute yourself but you can easily damage the keyboard if you are not careful.
Unless you are experienced in electronics repair that is as far as you should go.
Oct 23, 2017 | Yamaha Music
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
BEHRINGER K3000FX will not power on
It may be likely that you've blown a fuse. This will require removal of the amplifier unit from the housing. The fuse is a 100-120 V~: 6.3 A H 250 V. You should be able to find this in most places. If the fuse is not blown, then the unit must be sent in for servicing.
Feb 18, 2015 | Behringer Music
B115D
Hi, your amp has a short if the fuse is blown - it needs to be repaired - we can fix it - look on ebay. Thanks.
Mar 12, 2014 | Behringer Eurolive B115D Powered PA...
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Roland ac 60 sudden loss of power. Is it the fuse?
If you mean it's completely dead, no lights or anything, then probably the fuse is blown. The question then becomes"what caused the fuse tio blow?".
If however, by loss of power you mean it's quiter but still producing sound, then the fuse is not blown.
Sep 08, 2013 | Roland Ac60 Acoustic Chorus Guitar...
Peavey cs1000x amp fuse blown
Power amp transistors failure.
Jan 18, 2012 | Peavey Music
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Good evenin' pluged a dx626 to 220V with all as it was from stock. it light for a moment and from that time doesnt work. problem in fuse? please help
It could have blown the fuse. The fuse is a part of where the power cord plugs in behind a little cover.
Most of the electronics is fairly well protected. If fuse is blown, replace with identical size and try it once. If it blows again, some parts in the power supply are damaged and will require service.
Apr 16, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a Lowery Genie 44, with a blown fuse
Do not change the fuse without finding out why it is blowen. If the glass is black DO NOT even think of changing it or you will cause more damage.
I think if you take out the fuse you will find the raring under the end caps of the fuse.
Nov 02, 2009 | Music
Ampeg BA112 1x12' Bass Combo Amplifier Logo
63 people viewed this question
Top Ampeg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Ampeg Music Expert? Answer questions, earn points and help others
