Question about Directed OHD700 Car DVD Player
Screen not working
The screen stays blue while the DCD player is running.
I have a Sony DCD Recorder (RDR-HX780) and Sony 40" 1080P LCD TV (KDL40S510) "tripple checked lines and HD cable connection." Problem (which occurs randomly and is anoying): When switching to DVR or...
Try this: got to www.sony.com mouse over "support" then click on "drivers/software" enter your model #(s) and then you can check for firmware updates, the symptoms that you list, unfortunently are somewhat common when connected via HDMI cables.
Check for updates on both product that you list.
Good luck !
Jan 31, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Brand new never used Curtis dvd 8017
Give it a about 24 hours. It might need to declimatize. Also, thry charging the battery pack first and/or try turning it on with the power adapter only (battery pack off the unit). If this does nothing, they to get or borrow a voltmeter to make sure the power adapter is giving out a votage. This will troubleshoot wether it is the unit or the adapter. Let us know how it went.
Jun 25, 2008 | Curtis DVD8017 Portable DVD Player
I have a panasonic plasma screen(no tv) and have been able to set up sky using an s video cable. Unfortunately I am not able to get the dvd player to work. I can get the picture but no sound ......any...
How are you connecting the DCD payer to the TV? If by chance you are using a DVI cable then you have to run the audio cables seperate from the DVI as DVI only sends video information. HDMI on the other hand sends picture and audio information on one cable.
Jun 20, 2008 | Panasonic Televison & Video
Sansa m250 is frozen on initializing screen
my e200 does that im sooo pissed it just stays on the screen turns blue than goes back to home screen. i let the batteries run out and the same thing still happens!!
Nov 21, 2007 | Audio Players & Recorders
MP3 Player Plays music but the screen stays black
i think the screen might be at the end of its life.sugest you get a new screen.if it still dosent work sugest you get a new mp3 player
Nov 04, 2007 | Philips HDD1630 MP3 Player
Sansa e260 screen stays black at power up.
Have you tried holding the menu button down for 30 seconds to reset the devise?
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
The Screen Stays black and the ring turns blue and thats it
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Oregon Scientific MP3 120
Keeps looping from a blank Blue screen to off. Will not turn on and stay on. also will not stay turned off
Aug 26, 2006 | Oregon Scientific MP120 MP3 Player
Car Audio & Video Logo
42 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
