Question about Dewalt 6.3 Amp Dry Wall Screwdriver
Cord replacement cord got pulled out of gun cant find where plack wire from plug cord goes on gun dewalt type 4 screw gun
  • David Ford
    David Ford May 11, 2010
    give me the model number and I will get one faxed to me and let you know
    Problem Solver:
  • 8 Answers
It goes into the hole on the underside of the switch
Posted on Oct 29, 2011
    Habit-Forming:
  • 174 Answers
Try this web site .you will need your model .number http://www.toolpartsdirect.com/dewalt/dewalt-18.html
Posted on Jun 01, 2009
How to replace brushes in a drywall screw gun
Take off the three screws in back of the handle and you should
see the brushes when you remove the back handle piece.
you can change the carbon brushes alone or you can change the holder also if its damaged ,
Aug 12, 2014 | Dewalt Drills: 4,000 RPM VSR Drywall Screw...
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Replacing the driver tip on Dewalt Dry Wall Screw Gun
yes,when you look at the front portion of the gun, the tip nozzle thing is actually two separate external parts. The foremost aluminum nozzle and the twisty black plastic thing behind it will pull straight off the piece that is reverse threaded onto the gear box.
Apr 08, 2010 | Dewalt 6.3 Amp Dry Wall Screwdriver
I have two dewalt 1/2 electric drills and the extension cords are cracked. how can i replace the extension cords?
You will need to lay the drill on a bench then remove all the screws that hold the two halves of the case together, carefully pull the case apart to expose the wire connections
Mar 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Replace a cord on a grinder
take the handle screws out and there will be 2 screws on the trigger holding 2 wires in and 2 screws holding a bracket to keep the wire from being pulled out. replace it with a new cord and 2 new connectors. the wire is a 14-2 and you will need about 4' of it.
when putting a new plug-in on the end put the black wire to the brass side and the white wire to the chrome side.
Aug 10, 2009 | Dewalt D28114 Angle Grinder
Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Mar 25, 2009 | Dewalt Drills
Need help to reconect power cord to my dw268
If you go to the Dewalt service center online you will find an exploded view diagram of your tool, and usually an owners manual as well. Try this link:
http://www.dewaltservicenet.com/SearchResults.aspx?q=DW268
I hope this helps you to sort it out. Good luck!
Mar 22, 2009 | Dewalt Versa Clutch Tek Screw Gun DW268
Dewalt 6.3 Amp Dry Wall Screwdriver Logo
178 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
