Question about Magic Chef CER3740 Electric Kitchen Range
Elements won't heat
Not the product I listed as my model was not avavilabe. Old stove (probably 1985) Have the old manual and it says Magic Chef Electric Range Model 35FA-92LX. Surface and oven elements won't heat. Just stopped working one day. electricity still flowing to unit as oven light is working, but not the surface/oven indicator lights. unit is plugged in properly, circuit breaker not tripped.
I removed and reinserted all surface burners just to be sure they were inserted properly.
  • shani2020 Mar 12, 2009
    no, I have not...I do not own a voltmeter...but can borrow one from where I work....I will do so tomorrow and report back.
  • mark milligan
    mark milligan May 11, 2010
    Have you tested for voltage at the burners?
the dr
  • 447 Answers
SOURCE: magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Posted on Oct 04, 2007
SOURCE: have a magic chef oven, f1 display after self cleaning
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
Posted on Jan 02, 2008
  • 85 Answers
SOURCE: oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
Posted on Nov 14, 2008
  • 12 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Posted on Feb 20, 2009
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
I just moved in my condo with a magic chef gas stove/oven without a manual. I tried to use the broiler but I can't seem to make it start after pressing the button "broil". It is about 10 or 11...
Hello Bocsabh,
The model number will either be inside the door of the oven on the face usually and/or is located at the rear/back of the item. There should me a model and serial number listed on the plate. Once this information is found it will be alot esier to help you with your current problem.
Please post back to this thread and I will be glad to help you.
Thank you for chosing
Mar 09, 2011 | Magic Chef Toaster Ovens
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Magic chef stove
Oct 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Magic Chef CER3740 Electric Kitchen Range Logo
37 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
