Question about Cyberhome CH-DVD 300 DVD Player
No picture or sound
I have acyberhome dvd model 300.dvd was set for y pb/cb pr/cr video audio.dvd was given to me and now i get no audio or video.how can i reset to factory default settings?
  • glw100551 Mar 24, 2009
    i did have audio,but no vidio. i pressed the stop button on player for five seconds and got a picture.
  • 80 Answers
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Posted on Mar 25, 2009
Why am i getting a pink cast when playing dvd discs?
Try changing your settings from RGB to Y Pb/Cb Pr/Cr. Its in the BD/DVD Video Output Format settings. Seems there has been a firmware bug and this is the current fix.
Aug 10, 2014 | Panasonic DMR-ES10 DVD Recorder
Dvd player only plays in b&w, and connectors dont seem to match up with tv
Go into the player's setup menu and make sure it's set for the kind of connection you're actually using (component, S-video, composite). Also make sure the connections are pushed "all-the-way-in" Lose connections can cause B&W picture.
Sep 09, 2007 | Televison & Video
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I have no signal with the video component (Y, Pb and Pr)
You may have to set-up the DVD player for component (Y,Pb,Pr) output instead of S-video. You may have to set DVD player to progressive-scan or 720p or 1080 video out, also.
May 02, 2010 | Cyberhome CH-DVD 300 DVD Player
The tv has a green screen
If you're running Y/Pb/Pr connection, then double check that you have the connections in the right place.
Also make sure that both devices are set to Y/Pb/Pr and not Y/Cb/Cr. Should be able to find this in menus if it's an option to switch.
Apr 08, 2009 | Samsung LN-T3253H 32 in. LCD Television
Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Dec 09, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Connect dvd player
can you please post the input/output specs of your tv/player? it will be much easier to help you if i know whats flying here. thanx
Jan 17, 2008 | Televison & Video
Cyberhome CH-DVD 300 DVD Player Logo
183 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
