Question about Bushnell Medalist Rangefinder
Bushnell medalist displays 1888 yds
When depressing button on bushnell medalist display shows 1888 yd
  • Yves Mentgen
    Yves Mentgen Sep 24, 2016
    I have the same problem!
  • Yves Mentgen
    in the display you can see all the symbols: 1888 YM , the flag, temperature 18 degrees , black triangle an 888! Everything disappears after 30 seconds. I don't get any real dstance!
SOURCE: bushnell 400 rangefinder won't show yardage
does anyone have the same problem? How do you fix it?
Posted on Nov 30, 2007
SOURCE: Bushnell Tour V2
This happened to me on the first round of use. I replaced the battery and it worked fine. I guess the battery that came with the unit was not very good
Posted on May 25, 2008
SOURCE: error code er6
Take the nice cover and neck strap off rangefinder to use on another item. Next use the rangefinder for hammer. boat anchor, etc. Seriously though the problem occurs often in the Bushnell rangefinders and it cost more to fix than to replace with a better brand. A $179.00 original cost rangefinder cost $10.00 to ship back to Bushnell and another $235.00 for repair of a non specified problem for a grand total of $245.00. I consider this a rip off from Bushnell.
Posted on Oct 09, 2008
  • 133 Answers
SOURCE: bushnell medalist pinseeker rangerfinder
You must use alkaline batteries only.....Heavy duty batteries dont generate enough current to power the laser properly...
mtg
Posted on Apr 24, 2009
  • 133 Answers
SOURCE: Nedd battery cover for Bushnell Medalist
call Bushnell at 800.423.3537
ask them for one...about 7-8 bucks
mtg
Posted on Oct 08, 2009
What is your favorite golf rangefinder, and why?
Bushnell Scout DX Rangefinderis my favorite one. It's a fantastic range finder.
It's offers some amazing feature and specification like...
  • 6x magnification
  • Range between 5-1000 yards
  • 3-volt CR2 Battery
  • Rangefinder Accuracy 5 yds
The Bushnell Scout DX Rangefinder will help you to pick from 3 different user modes by pressing the Mode button at the left side of the unit. First is the usual mode which can be used for most purposes up to 1000 meters and works well towards the pretty reflective surface.
When turned on, the Scout 1000 Laser Rangefinder liquid crystal display (LCD) will directly display icons like the bow and rifle mode. The bow mode will provide you with true horizontal distances from 5-99yd away, depending on the angle. The rifle mode, however, will permit you to get the angle and drop/holdover of your shot to the target from 100-800yd.
Jun 02, 2018 | Optics
Change from meters to yards on bushnell chuck adams rangefinder
First, remove the battery then replace it to reset the unit, then ...
Taken word for word from the manual: While looking through the eyepiece, press and hold the POWER button down for approx. 5 seconds. During this time all liquid crystal segments and icons will be displayed. As you continue to depress(hold down) the power button, the display will toggle back and forth between Yards and Meters. Once the unit of measure desired is displayed, simply release the power button. The device will return to the last unit of measure setting used each time the unit is turned on.
Sep 12, 2012 | Bushnell Optics
My Pinseeker 1500 picks up objects at close distances (50 yds +/- but not at longer distances. Whats wrong and is it an easy fix?
This unit needs an alignment. If it has oily looking spots in the display it also needs the LCD replaced. If it is less than 2 years from the date of purchase its still under warranty.
Bushnell repair center
8500 marshall drive
Lenexa, ks 66214
# 800.423.3537
$50.00 for alignment
$15.00 if the LCD needs to be replaced
$15.00 for all other maintenance performed.
Oct 08, 2009 | Bushnell PinSeeker 1500 20-5103...
Nedd battery cover for Bushnell Medalist rangefinder
mtg
Oct 08, 2009 | Bushnell Optics
I have the yardage but the flag in the left side of scope doesnt appear (mode) and some lines are missing (--- Y)as well as the Y and the targeting O are faint.
If your Pinseeker Medalist (20-1354) is not showing all the digits in the display.....Return it quickly. You should have 2 years warranty. Look on that little narrow strip on the back. It will show the serial number and the date of manufacturer. (you got 2 years from the date of purchase) If you need to copy your receipt do so. They will fix it.....
Good luck and hurry!!!!
mtg
Jun 06, 2009 | Bushnell Medalist Rangefinder
Bushnell 400 rangefinder won't show yardage stuck on 888
If the unit is stuck on 1888 the circuit board inside has lost its programming. Sounds like its about 10+ years old. Bushnell doesn't work on them anymore. If you use it for hunting I would suggest the Scout 1000 with ARC compensation, if you use it for golf look at the Medalist. You can see them both at bushnell.com
The hunting rangefinder will run about 250 bucks
The golf rangefinder will run about 220 bucks.
Both use advanced target locking systems.
mtg
Jun 01, 2009 | Bushnell Yardage Pro 500 Rangefinder
Bushnell medalist pinseeker rangerfinder
mtg
Aug 23, 2008 | Bushnell Medalist Rangefinder
Pinseeker 1500 just illustrates 1888 YM
Here's where you can get the manual:
http://www.bushnell.com/customer_service/manuals/rangefinders/20-5103_Pinseeker.pdf
I'm having the same problem, but the normal yardage seems to be working fine. I tried calling Bushnell, they said I would have to send it in to them and they would fix it. I'm thinking it's got to be something easy to fix.
Does anyone have any answers?
Oct 18, 2007 | Bushnell PinSeeker 1500 20-5103...
Bushnell Medalist Rangefinder Logo
519 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
