Question about Electrolux AOS201GAEU Air O System Combi Oven Half Size gas (20) 12""x20""x2 and a half"" pan capacity rack (6)...
10 yr old electrolux 20 tray combi has error code e69
2 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
What does error code E60 mean?
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Apr 21, 2016 | Electrolux Washing Machines
What does it mean if the car runs good until it warms up then loses power
Fuel supply, or sensors providing information to the ECU. Take by your favorite auto parts shop, ask nicely to read your error codes. That will probably give you an idea. I found with my 20 yr old car that corrosion on sensor connections caused error codes so clean and scrape to bright metal. fixed the errors and the bad behaviors caused by them.
Apr 10, 2015 | 1993 Jeep Grand Cherokee
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Dado
Feb 21, 2015 | Electrolux Washing Machines
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
HOW DO YOU FIX AN ERROR CODE EFUN up on an air o steam oven
check the capacitance of capacitor of cavity fan,if out range then replace.
Sep 10, 2012 | Electrolux Air-o-steam Combination Steam...
The xbox has a error code 69 and I cant seem to fix it. So if you know what the problem is please help me out and its on the forth person spot
Hello sir
It's Code E69
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Apr 08, 2010 | Microsoft Xbox 360 Console
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Electrolux AOS201GAEU Air O System Combi Oven Half Size gas (20) 12""x20""x2 and a half"" pan capacity rack (6)... Logo
96 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
