Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
My Sta-Rite irrigation well pump MSE-6M82 turns on but no water. How do I prime the pump?
1 HP 115/230 V Motor C48L2FC4VHC3
    Top Expert:
  • Sta Rite Master
  • 6,465 Answers
Possible bad seals replace
Posted on Dec 05, 2017
4 Suggested Answers
  • 16 Answers
SOURCE: pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Posted on Aug 23, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: lost the prime on sta rite pool circulation pump
HI THERE , YA GOT THE BEST PUMP ! HAVE YOU HAD TRASH IN THE POOL ? THIS CAN MAKE ITS WAY TO THE PUMP AND PLUG THE IMPELLER , COULD BE SHAFT SEAL , THERE GOOD FOR 3-5 YEARS. UNLESS YOU HAVE STARVED THE PUMP FOR WATER,THIS KILLS A SHAFT SEAL.. TRY PRIMMING THE PUMP AGAIN. IF THAT NOT WORKING CHECK THIS LINK OUT IT WILL SHOW YOU PICTURES ON HOW TO REMOVE THE PUMP, SO YOU CAN LOOK AT THE IMPELLER .. IF I WAS OF HELP LEAVE ME A REVIEW.. GOT 2 BACK 2 FIX'N PUMPS.. GOOD LUCK..JAY .. http://maps.google.com/maps/place?cid=9186213048628859752&q=WHEN+SERVICE+CALLS+LONGWOOD+32750&hl=en&gl=us&ved=0CA4QtQU&sa=X&ei=ZLT2TMO3CangyQTS58z5Bg
Posted on Dec 02, 2010
  • 366 Answers
SOURCE: pump was running until turn
either debris in pump causing impeller to hang, or you need a start capacitor.
Posted on Aug 14, 2011
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
The well pump is running, but no water is supplied to thr irrigation lines. once I put water in the pump housing by removing the pump guage the pump pumps water through the irrigation lines. when it shuts...
Sounds like you have an air leak. First check your fittings, next carefully run water over the pump seals (avoid getting water on the motor or you'll hurt yourself and the pump if not worse) the pump will prime if the leaking seal is covered with water. Take your time and be careful and it should only be a matter of a loose fitting or simple seal swap.
Mar 08, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Well pump Sta-Rite MSE-7 now and then won't kick in and buzzes --I replaced the pressure switch-Same thing --Sanded internal points on top of motor same thing pump gets warm contacts in pressure switch...
In the back of the motor you will find a start capacator. This will be a brown or black cilinder 1" around x 2" long. With the power off unhook the wires to it and note where they go, their will be two or three. You will need to go to a motor shop or a good pool store to get a new one. Then just plug it in and you should be good. If this dosen't help than you may have problems in the windings of the motor and will need to replace it.
The start cap supplys a boost of power to get the motor turning. Once it starts then the cintrifical switch kicks out and opens the points in the back of the motor. When it goes bad then the motor just hums and won't start turning. Be sure to replace with the same cap. The numbers you need will be printed on the side of the cap. Good luck.
Apr 27, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
I had to take the motor out and put it back together now its not getting water what do I have to do. The motor works fine
If this is a self priming pump you will just have to fill the pot with water. If not you will have to open a valve and force some water through the system to prime the pump. This being done, if you still have no water you may have a suction leak keeping the pump from priming and may need a repairman at that point. Good luck.
Apr 25, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How do you prime a sta-rite mse-6 deep well pump?
Take the pressure guage off and pour water in the hole untill it fills the pump, then screw the guage back on and cranck it up. You may have to do this a few times depending on how deep in the grownd the water is.
Jan 26, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pump runs continuously with not water
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
83 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
