Question about Human Touch HTT-10i / HT-130 Robotic Massage Chair Recliner
I need the htt-10i-crp footrest operation cable
I need the inside lifting cable of the footrest
What does CRP mean
C-reactive protein
C-reactive protein (CRP) is a substance produced by the liver that increases in the presence of inflammation in the body. An elevated C-reactive protein level is identified with blood tests and is considered a non-specific "marker" for disease.
Elevated C-reactive Protein - CRP - Symptoms, Causes & Treatments
https://www.drweil.com/health-wellness/body-mind.../elevated-c-reactive-protein-crp/
Or maybe something in the link
CRP + computer Google Search
Apr 03, 2017 | Computers & Internet
My remote control HTT10-CRP which does not function any more.
you can open the case of you remote maybe there is 1 screw inside the battery holder or if there is no screw its only at clip type you can open it with the help of flat screw or knife...and then clean it with alcohol both the board and the rubber..
Sep 12, 2015 | Televison & Video
What do the initials C.P.R. mean as re. blood testing?
I think you mean CRP.. (C.P.R.) Is a rescue term meaning Cardiopulmonary resuscitation, But C-Reactive Protein (C.R.P.) Deals with blood testing This is sometimes called an acute phase protein. This means that the level of CRP increases when you have certain di sea ses which cause inflammation. CRP can be measured in a blood sample.
Mar 22, 2015 | Therasense Freestyle Test Strips
How to adjust the clutch on a 2003 sportster 883 custom
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with 1/2 inch wrench, loosen the jam
nut using a 9/16 inch wrench and back the jam nut away from the cable adjuster and then move the adjuster toward jam nut to introduce a large amount of free play at hand lever. THEN remove the locknut and bolt to free the left side footrest from the footrest support and then remove the footrest and spring washer and THEN using a T-27 TORX driver, remove the four TORX screws with washers to remove clutch inspection cover exercising caution to avoid damaging or dislodging the quad ring in the primary cover. THEN slide the spring with the attached hex lockplate from the flats of the adjusting screw. THEN turn the adjusting screw counterclockwise until resistance is felt THEN back off the adjusting screw 1/4 turn. THEN slide spring with hex lockplate onto the flats of the adjusting screw and if necessary, turn adjusting screw clockwise just slightly so that the lockplate slides onto the flats while also fitting within recess of the outer ramp. Replace the quad ring if it is very old, deteriorated or etc. and verify that quad ring is fully seated in the groove of the primary cover and a few well spaced drops of instant contact cement can be used to hold it in place. Using the T-27 TORX driver, install the TORX screws and washers to secure the clutch inspection cover in place and tighten the screws in a crosswise pattern to 84-108 in-lbs (9-12
Nm). THEN turn the cable adjuster clockwise away from the jam nut until all of the slack is eliminated. THEN pull the clutch cable ferrule at the hand control end of the clutch cable at the hand control lever bracket away from the clutch hand lever bracket to check the free play. You need to obtain 1/16 to 1/8 inch free play between the end of the cable ferrule and the clutch hand lever bracket i.e. while you are pulling the cable away from the clutch lever mechanism bracket there should be a space or freeplay of 1/16 to 1/8 inch or in other words if you can pull the clutch cable away from the clutch lever bracket that much you have the correct lever freeplay, so turn the cable adjuster as necessary to get this amount of freeplay between the end of the clutch cable and the clutch lever bracket on the handlebars. After you have adjusted the cable so that you have this freeplay then hold the adjuster with a 1/2 inch wrench and using a 9/16 inch wrench, tighten jam nut against cable adjuster and then pull the rubber cable adjuster cover over the cable adjuster mechanism. THEN place the spring washer over the lower inside hole of the left footrest support with the concave side of the spring washer facing the support flange. THEN align the holes in the footrest with the threaded holes in the support and spring washer and install the bolt and locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Aug 06, 2014 | Motorcycles
How do i adjust my clutch on my 2003 1200c sportster
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with one half inch wrench, loosen the jam
Locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Jul 11, 2014 | 2003 Harley Davidson XL 1200 C Sportster...
Install foot rest
If you have the swing on footrests or legrests for a Pride Jazzy series with 2-pins on the hanger brackets please be sure that the hanger brackets are properly installed on the chair with the pin side of the bracket facing to the outside - not inside. To put the footrests on - align the lower pin first with the footrest at a 45 degree angle to the outside of the chair. Then align up the top pin and lower the footrest onto the hanger bracket. Rotate the footrest towards the front and lock the cam lock in place. If the cam lock has a handle that is bent it will interfere with the lock and need to be replaced or bent back in place.
Nov 13, 2013 | Pride Jazzy 1113 Power Chair
I need a remote control for my HTT-9 Human Touch Massage chair.
My htt-9c would beep and not work. E-mailed company and they said chair was out of production for a while and they would give me a discount on a new one(no replacement parts). I peeled the sticker off of the top of the remote and had to remove 4 tiny screws. Inside the remote there was 2 more tiny screws to remove. Went to radio shack and got a 25' phone cord for 11 dollars and plugged it in the remote and back of chair. Fixed the problem
Oct 23, 2011 | Interactive Health Refurbished Htt 10crp /...
How do I keep the footrest up on my Raider AT+?
It is important to realise that there is a swinging support underneath the footrest. To lift the footrest, push the swinging support backwards, and to lower the footrest, pull the swinging support forwards.
If an instruction manual would be useful, ask service@bebecar.co.uk
May 12, 2010 | Bebecar Raider AT Stroller
I have an HTT-10i-crp robotic massage chair pp although power is showing going to the chair -- it stopped working. Any ideas?
Have you checked to see if the main on/off switch on the back of the chair got pushed to the off position by accident? It's near the bottom of the back of the chair.
Jan 04, 2010 | Interactive Health Health & Beauty
Not getting any power to chair
Make sure there is power at the outlet. Check the fuse panel. If there is still no power then check to make sure there is no GFI (ground fault interupt) switch on the chair itself. The GFI is a 2 button switch that will say "Reset" and "Test"
Nov 30, 2008 | Interactive Health Black Leather Ht 130...
Human Touch HTT-10i / HT-130 Robotic Massage Chair Recliner Logo
37 people viewed this question
Top Human Touch Furniture Experts
ray gallant
Michael Vincent Cruz
Are you a Human Touch Furniture Expert? Answer questions, earn points and help others
