SOURCE: WATER ON THE FLOOR UNDER FREEZER DOOR
dear jim
there is drain line get chocked up with ice.Please open freezer evaporator cover u will find there is ice blocked in drain tray,melt it with hot water,check drain heater attached to the drain tray,if defective replace it,it will work fine
regards
sandy
SOURCE: our Samsung fridge freezer is
the water is coming from the freezer
when is defrosts. the drain line is in the back wall of the freezer and may be
clogged up with ice. clean out the freezer and pour some hot water in the very
back of the freezer, this will hopefully unclog the drain. if not, then you
have to take the back wall out of the freezer to get directly to the drain
line. there should just be a couple screws holding it; it is just an aluminum
or plastic panel.
Mike
SOURCE: samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
SOURCE: WATER LEAK ON THE FLOOR
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)
SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
