Question about Symbol PPT 2800 Portable Terminal
How do you rest password for symbol PPT2800 - Symbol PPT 2800 Portable Terminal
I need help to restting my google password .. I tryd everything they said to and its still not working
Change your Google Account password
Forgot password
If you forgot your password, type your username on the trouble signing in page to reset your password.
Change password
To change your Google Account password, go to the change your password page.
Or you can follow the steps listed below:
  1. Go to your Google Account Settings page.
  2. In the Signing in section, click Password.
Remember that changing your Google Account password changes it for all Google products you use, like Gmail and YouTube, so be sure to use your new password the next time you sign in.
Password requirements
Here are a few rules to keep in mind when choosing a password:
  • Passwords must be at least 8 characters long.
  • You can't reuse a password that you've used in the last year.
  • Passwords can contain the following characters:
    • Upper and lowercase letters (A-Z and a-z). Please note that passwords are case-sensitive, so a "G" is different from a "g".
    • Numbers (0-9).
    • The following symbols as well as spaces: ! " # $ % & ' ( ) * + , - . / : ; < = > ? @ [ \ ] ^ { ' } ~
  • Certain passwords that are easy to guess like "12345678" can't be chosen.
Creating a strong password
To keep your account safe, here are a few tips on how to create a strong password:
  • Use a different password for each of your important accounts, like your email and online banking accounts. Choosing the same password for each of your online accounts is like using the same key to lock your home, car and office - if a criminal gains access to one, they can break in to all.
  • Use a mix of letters, numbers, and symbols in your password.
Feb 01, 2015 | Google Computers & Internet
Tip
Acer 5334 - BIOS/SYSTEM Password Removal
Many people wonder how to removal Acer BIOS and System passwords. If the system is bootable to windows you can use the Acer eSettings Management software included with your computer to remove or set the passwords.
This guide will show you how remove a password using a hardware method that is faster than software as well as successful when you can't load software due a boot password.
First thing first, this procedure is done with the laptop battery still in the unit.
What you need to do this:
  • Phillips Screw Driver
  • Plastic pry stick
  • 1/4 inch wide metal shim or medium flathead screw driver
Procedure:
  1. Turn the unit upside down.
  2. Remove the screw that holds the middle panel that covers the memory and wireless adapter.
  3. Carefully use the plastic pry stick the tug the panel off of the system to expose the components.
  4. Remove all memory from the unit.
  5. Locate the white square box with the symbol "J1" next to it.
  6. Open the computer and have it rest on so that the screen is down and the rest is upward.
  7. Now take the metal shim or flathead screw driver. Scratch the 2 solider points just enough to remove the protective enamel.
  8. Place the metal object across the two solider points so you short them.
  9. Turn the computer on for 5 seconds then turn it off.
  10. Remove the short and place one memory stick in the computer.
  11. Boot up, hit F2 to enter BIOS and verify system passwords removed.
  12. Shut down and place additional stick of memory if included
  13. Replace the cover and screw.
At this point you should be good to go. Good Luck
on Dec 22, 2010 | Computers & Internet
Facebook com login sign in
sometimes having a symbol first on your password may not be accepted. try using letters first then follow it with numbers and symbols. if that does not work then you will need to use the forgot password link.
Jul 21, 2014 | AccessData Password Recovery Tool Kit (ftk...
I need reset the default password for a symbol WS5100
Forgot your Windows password? A Windows Password Reset Disk could do all the job for you, it can reset your lost or unknown Windows password safely and quickly without login, you can create a Windows password reset disk with the tool Windows Password Breaker, then use it to reset your password.
Dec 12, 2010 | Symbol WS 5100 Wireless Switch - P/N...
Changing password
goto control panel click it,.... goto Add or Remove user Accounts click it,...
drop down appears, asks for permission to continue or tells you you are not high enough on food chain --I have a vista operating program- ask for adminstrators password...
click... goto main User Accounts Page
click...change password
use a password that has at least six symbols,,,a capital letter,,,,some lower case letters,,some numbers,, adds up to six symbols ... ex.. Job226
Nov 27, 2010 | Computers & Internet
How do i completely rest the mc70
you need to use a piece of software from motorola, follow the link below and download "MC70cleaners"
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11744&sliceId=&dialogID=175684178&stateId=1%200%20175682106
unzip it onto the root of an SD card, put SD card in EDA,press power +1+9 together after 20 seconds release them, press top right button, updater will start, u need the mains plugged in, after it has finished it will boot into windows mobile.
Aerv 74
Apr 23, 2010 | Symbol MC70
How do i reset my phone
Main Menu> Settings> Master Reset> Click the "All" Tickbox> then type this password *2767*3855#
with all of the symbols.
Apr 06, 2009 | Samsung U900 Soul Cellular Phone
I recently bought a used Symbol DC50. It has an administrator password that is unknown to me. Is there a way to reset this? Please say yes :)
They all do. Either get the product reference guide from www.symbol.com (Beware, product reference guide, not the quick reference guide) or wait until monday when i am back at work and get it for you or another alternative, try the usual default passwords that Motorola uses in their equipment nowadays. "Symbol" "symbol" "Motorola" or "motorola".
If this doesn't work, please get back to me and I will help you out on monday.
Please do not rate this solution either good or bad until you have a final answer or otherwise i will not help.
Apr 03, 2009 | Symbol LS 4071 Handheld
Symbol 9090
Hello - we service barcode equipment - I think the best way is to reflash the unit.
Let me know if you need more information:
Ian
Account Manager
DC Solutions
ianv@dcsolutionsonline.com
Sep 11, 2008 | Computers & Internet
Symbol PPT 2800 Portable Terminal Logo
52 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
