Question about Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Need manual for a stanley 2.8 hp wet/dry vac - Shop Vac 584-06-00 Canister Wet/Dry Vacuum
  • 744 Answers
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
Posted on May 16, 2009
  • 9 Answers
SOURCE: Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Posted on Jun 18, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
Asbestos 56
  • 191 Answers
SOURCE: I can't find the owner's
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Posted on Jul 23, 2011
Who makes the electric motor for the Stanley 2.8hp vacuum
Almost for sure it is produced in a no name contractor of parts.
Sep 06, 2016 | Stanley 2.8hp 4 Gallon Stainless Steel...
Shop vac 1.1
try the link below if you wont the manual or parts click on your vac to download manual.
http://www.shopvac.com/wet-dry-vacs/default.aspx?hp=Any&ts=Any
Sep 15, 2012 | Shop Vac Vacuums
I have a 4hp stanley wet dry vac, and when i try to **** up liquid i have no suction, and no longer have the manual
Locate the three tabs on the float cage where it snaps to the top/motor. Use a flat head screw-driver to gentle pry back each tab and pull the float cage off. In the middle under the motor, is a round hole about 1 inch diameter. Inside it is a fiber filter. with the screw driver gently pull out the fiber filter. It\'s about an inch diameter. Wash it well, and replace it over the impeller and now that baby will suck.
Feb 28, 2011 | Stanley Vacuums
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac 584-06-00 Canister Wet/Dry Vacuum Logo
63 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
