Question about Karcher K 5.85 M Electric Pressure Washer
Karcher k 3.96m low water pressure - Karcher K 5.85 M Electric Pressure Washer
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
mxtras
  • 194 Answers
SOURCE: my karcher pressure washer seems to oscilate on
The most typical reason for this is that your supply pressure or volume is not sufficient. Try using a larger diameter hose.
Posted on Nov 10, 2009
  • 88 Answers
SOURCE: karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Posted on Jan 20, 2010
  • 553 Answers
SOURCE: low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
Posted on May 26, 2010
Karcher high pressure washer has very low water pressure
make sure that the hose connected to the pump is not kinked and the flow is adequate for the pump need
Oct 30, 2016 | Karcher Garden
Karcher k 5.700 very low presure and how to fix it thanks
1 water inlet filter clean ?? not limed or ??
2 nozzle clean.
3 pressure control valve properly screwed
Sometimes water hoses are provided with a slot at the hose connection with an internal water seal, which is the wrong way to the water tap instead of to the machine
Jan 23, 2016 | Karcher Garden
Water pressures varies from high to low. Not idling right
checked for a problem nozzle, low inlet water pressure to the pump or faulty pressure regulator.
May 09, 2015 | Honda Karcher G2400HH-R Pressure Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k3.91 how do i change from just water to soap
Twist the end of the nozzle or jet pipe until you get low pressure. This will **** the soap through
Aug 16, 2009 | Karcher PSI Electric Pressure Washer
Karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
