Question about Yaesu FT-726R Transceiver
Meter lamp replacement 726r - Yaesu FT-726R Transceiver
Replacement mic.
Check with "Ham Radio Outlet" online. They should have a replacement.
Feb 22, 2014 | Yaesu FT-726R Transceiver
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
How to change battery in ft.726r
You will need to disassemble all the way to the board level to unsolder the battery. It should be on the "control" board.
Sep 08, 2013 | Yaesu FT-726R Transceiver
Yaesu FT-726R repair shop?
The cheapest way to repair your Yaesu, is to find a friend who is an amateur radio operator, these people know radios, and work on radios as a matter of course as their hobby, otherwise it's off to a radio workshop you go, and be prepared to part with some cash.
There are no freebies with quality branded radios, only cheapies, if you know the right people.
I hope this answers your query, and by the way, I'm in Australia, you never mentioned your location.
Cheers,
Peter
May 30, 2012 | Yaesu FT-726R Transceiver
How do I replace the RF meter light in a Cobra 29NW? Thanx Breeze Neshanic Station, NJ
The light is a small 12 volt lamp that you should be able to find a similar one at Radio Shack. The wires are soldered to it but you can cut the wires and solder them to the new lamp. The lamp is held in place in the meter by a rubber grommet. You can take the case off the radio and just pull the lamp out of the side of the meter. Don't get to power full of a lamp or you will melt the meter.
Feb 08, 2010 | Cobra 29 LTD CB Radio
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Yaesu FT-726R Transceiver Logo
54 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
