Question about Microsoft Xbox 360 Console
Error code e74... help
See subject
    Problem Solver:
  • 16 Answers
Hi! Here are some steps that you can use to try to resolve the issue.
1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
3. If the steps did not resolve your issue, your console may have to be repaired.
4. Try contacting Xbox Customer Service. For USA or Canada, it is 18004MYXBOX and ask for the Hardware department.
Posted on Mar 12, 2009
What would be wrong when e 74 stays up on the screen on my x box 360
An E74 error is indicated when the lower-right quadrant of the ring indicator flashes red and displays an error message in multiple languages: "System Error. Contact Xbox Customer Support", with the code E74 at the bottom . The error is caused when there's a video problem, because the Xbox 360's hardware scaler chip is damaged.
Start the repair process online.
Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about the E74 warranty extension, see the following article:
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 30, 2011 | Computers & Internet
System error E 74 is coming up on my xbox360
This problem occurs when the Xbox 360 console experiences a hardware failure. To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If you are experiencing this problem, your Xbox 360 console must be repaired at our service center.
https://myservice.xbox.com/en-us/Pages/Welcome.aspx to start the repair process.
Mar 03, 2011 | Video Game Consoles & Games
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
E74 flashing on my xbox
"E74" error code is caused by a memory storage device attached to the Xbox 360 encountering a hardware error. You can try to remove the HDD and restart the console without it, if the E74 code won't appear it means that you need a HDD replacement. But if it still does appear, there is a general hardware failure in the system and it might require servicing. You can contact Microsoft Xbox Support for it to be fixed, out of warranty console will be charged $99 dollars by the way. The warranty period is three years.
Thank you !!
Jun 16, 2010 | Microsoft Xbox 360 Console
E74 error code for xbox
The E74 error is caused by the scaler chip at the back of the console taking too much heat. To fix it you need to stop the heat build up.
You can do this yourself using a good guide that will show you how to fix it with household items or you can send it in and they will fix it for you.
Feb 02, 2010 | Microsoft Xbox 360 Console
Everytime i switch on it shows errror E74
The E74 error code occurs when the Xbox 360 console experiences a general hardware failure.
To confirm your console is displaying the E74 error message, follow these steps:
If your console continues to display the E74 error message, it requires a repair.
Login at the following website to start an online repair support case
(Free repair if console is still under warranty, $99.00 if not)
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
or contact Xbox support at 1 800 4my xbox
(Free repair if console is still under warranty, $120.00 if not)
Jul 23, 2009 | Microsoft Xbox 360 Console
One red flashing light e74 rror code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known
to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected
directly to the AV cable) in rare cases it is the GPU.
If you just got it take it back, if you have had it for a little while you need to call microsoft and send it off for repair
Aug 21, 2008 | Microsoft Xbox 360 Console
When i turn my xbox on it say on the screen e74 an one red light is on
E74 is an error with your AV cable and or your GPU / Scaler chip. If you can swap out your AV cable to see if that works if not you will have to contact MS, as there is no quick fix for this error if your cables dont work. Hope this helps.
May 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
