Question about Cameras
I need a charger for my Babyliss 7230U Rechargeable Mens 10 in 1 Titanium Grooming Set. I don't mind if it's a regular plug charger.
My charger broke and I need a new one. I do not care if it is a regular plug one and not the same as the original.
escapement
  • 2334 Answers
SOURCE: I NEED A NEW PIN FOR THE g952906 mens watch.
Yes, you can buy them on eBay. They ate called spring bars or spring loaded pins. All you have to do is to measure the distance between lugs on watch (the place where the band is attached to the watch). This will be exact spring bar size you are after.
Rate, please.
Posted on Mar 28, 2009
eradiostore
  • 1654 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
pabloloco
  • 2335 Answers
SOURCE: My Garmin nuvi 205 keeps saying it is connected to
When your Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Posted on Mar 18, 2010
sonicboomele
  • 1557 Answers
SOURCE: I need a new charger,
most electronics supply shops like cady shack will be able to match the old charger for another if you take it in with you
Posted on Jan 02, 2011
Testimonial: "Thank you!!!"
  • 8909 Answers
SOURCE: I have a Babyliss 7053U
I have the very same kit too, without instructions. If you look at the plastic bits that go on the shaver they will only fit on one way.
Posted on Mar 12, 2011
I overcharged my babyliss grooming kit now it won't work
You will have to get new batteries. In Greece, there are specialist battery shops that supply or charge batteries for every possible use. One of these shops replaced my batteries for 8 euros and now my hair trimmer is as good as new again. The trimmer appears to take two common AA sized rechargeable batteries, so you should be able to change the batteries yourself.
Jul 01, 2014 | BaByliss 7053U Beard Trimmer
BABNT2091T
The Problem with BaByliss PRO Nano Titanium 1" Ultra Thin Hair Straightening/Flat Iron can be resolved if you call the company support line or web page.
May 10, 2014 | BaByliss PRO Nano Titanium 1" Ultra Thin...
Lost manual for babyliss 10 in one grooming kit
You should be able to get another one from the manufacturer. Try calling Babyliss customer service. Also, with the model number, a lot of manuals can be looked up online .
Apr 04, 2014 | Babyliss Pro 10 in 1 Titanium Grooming...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
How to fix my shaver?
try going to their web site to see if they have a parts picture, if they do the diagram will probably resemble what the shaver looks like with the parts separated and numbered so you can buy just that part, it should give you an idea of what it looked like before. I know they have sewing machine pictures like that so I am hoping they have them for shaver too! good luck hope it helps.
Nov 26, 2017 | As Seen On TV Health & Beauty
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
Batteries always low
If you're using regular alkaline batteries that?s fairly common. If you want longer life most people purchase rechargeable nickel-metal hydride batteries and a charger. Depending on the camera you?ll get 40 or more flash images out of a charging. I have two sets, one in the camera and one in the charger. Expect to pay about $5 to $10 for a set of four and around $10 or $20 for a charger, make sure its for nickel-metal hydride batteries and not the old style nickel-cadmium. Good luck and don?t forget to rate this post.
Mar 03, 2007 | Polaroid i832 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
