GATEWAY LAPTOP WONT LOG INTO ANYTHING SHOWS ME A BOX WITH THE FOLLOWING----SVCHOST.EXE-APPLICATION ERROR THE INSTRUCTION@0X75606EB5 REFERENCE MEMORY@0X00000008. MEMORY COULD NOT BE READ. CLICK TO TRMINATE , THE PROBLEM IS THAT WHEN i TRY TO CLICK OUT IT JUST GIVES ME THE ERROR TONE/SOUND AND WILLnot COME OFF SCREEN AND WILL NOT ALLOW ME TO GO ANYWERE ON LINE- E-MAIL -INTERNET NOTHING help
  • mrzzman51 Mar 11, 2009
    if i restore the system will i lose all saved files and such
  • 679 Answers
Restore it to the last good restore point, which should be yesterday, unless the files were all done today, you shouldn't loose anything other than the last day. Did you just try powering off by pulling the plug, and trying to restart. That should be the first thing you do. It may just have locked up, it happens. If you do implement the restore feature you can always undo it, It allows you to "undo last restore" so you have nothing to lose. If you can get into safe mode and run a spyware and virus program, you should be ok, otherwise, you can try the "repair" option in windows. If you have the recovery disks. Windows will also let you run chkdsk in safe mode which is sucessful about half the trime. You need to make a decision either way. If you "backed up" the drive you can get it all back, if not, then it's either try some of the suggestions here or take it to a repair store. I will tell you right now, that the repair store, "geek squad" or whoever, is going to tell you that they can't save the files, first of all they aren't trained to, and secondlly it will take too much time and effort for them to put into saving them. There are programs like "get data back" that I have on my machine, that will get unreadable data off of just about and drive deleted or not. It is forensic quality. But unless the stuff is ireplacable I would advise you against starting on a quest that is going to cost you a lot of money. It will cost you more than the computer cost. So try some of the suggestions and just keep letting us know where you are at, so we can try to help you through this, we do this because we like to help people, so the advise you get is going to be much more honest than a repair shop that sees you as a person in a position of weakness, because you now are relying on them to save you. Good luck and keep us informed
Posted on Mar 11, 2009
    Novelist:
  • 148 Answers
since when are you facing this problem if you know the date on which your system was working fine, try to do a system restore to that date hen it was working fine for doing system restore, restart your system and as soon as you see the Gateway logo start tapping the F8 key, you will see a menu that will give you the option to start in safe mode select safe mode and press enter, in safe mode i thoink you will be able to login without any problem,
now
here is a helpfull link to system restore
http://support.microsoft.com/kb/306084
further queries are welcome
if you find my solution helpfull please do rate me
  • 10,594 Answers
If you restore system in back dates, you will not lose any information or files till that date.
  • 15,935 Answers
Have you recently deleted a program?
Usually this happens when a program is in the startup Queue, but cannot be found on your PC.
Click start - RUN - type MSCONFIG
Under the STARTUP tab - un-check anything that is checked except antivirus software.
These are programs you have slated to run in the background at startup.
None are necessary except antivirus.
If you need additional ones also running - follow the same procedure and one by one add the programs with a restart to see if that is the program in question.
If you cannot get to the start menu after windows starts.... during startup press F8 (usually) and select "start in safe mode". safe mode" does essentially the same as i described above - it does not allow any programs to load except windows.
Thanks for using FixYa!!
  • 6,784 Answers
Hi, this is a virus. most viruses us this svchost tag to make it look like its normal procedure but, in reality, it has token over your PC. i recommend clearing the partitions and restoring the entire system with a recovery disk. this is the only way to defeat this issue. you can try to use the system restore option but i doubt if the virus will let you access that feature. the best way is to insert a window OS disk and restart the CPU or, use the recovery disk that your PC was shipped with to bring back order.
  • 158 Answers
Try to change your RAM
Otherwise for this problem of solution you need to format your machine which will completely solve your problems.
    Brigadier General:
  • 3,614 Answers
better try to do a system restore on your unit, some curropt file has to do the terminate of applications
  • micromaster
    micromaster Mar 11, 2009
    no. you will not lost your save file, it only restor it on the previous state.
Svchost exe error
upgrade to a newer OS helps alot
Jul 18, 2014 | Toshiba Satellite Computers & Internet
I'm receiving 2 messages from my webroot internet security essent
This sounds like a virus to me? you say you are receiving that message, please, is it Windows "Telling" you?, or some program "Telling" you? please clarify? svchost, is not something that should be deleting anything...Both TCIP & netbt are VERY important part of Windows, so I do NOT think, it should be allowed.
Feb 28, 2010 | Webroot Internet Essentials (83210)
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
New Laptop keeps shuting down with Error message
I recommend that you don't bother trying to fix this problem yourself.
Seeing as the laptop is new it will be under warranty, take it back to where you bought it or phone the manufacturer to arrange for it to go in for repair.
Tell them that you are getting the "blue screen of death"
They will either repair or replace the laptop free of charge and you won't have to pay courier charges either.
Regards.
Nov 13, 2009 | Gateway Computers & Internet
Need to fix svchost.exe the instruction at
I have a fix for it - it's somewhat lengthy, but it works. Follow the directions below to a T and you'll be all set.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Remove Corrupted Windows Update Files
  • At the command prompt, type the following command and press Enter
    net stop WuAuServ
  • Still at the command prompt,
    type cd %windir% and press Enter
  • In the opened folder, type the following command and press Enter to rename the SoftwareDistribution Folder
    ren SoftwareDistribution SD_OLD
  • Restart the Windows Update Service by typing the following at the command prompt
    net start WuAuServ
  • type Exit and Press Enter to close the command prompt
Reboot Windows
  • click on Start, Shut Down, and Restart to reboot Windows XP
Although this method may not solve all of the issues with a SVCHOST.EXE Application error, I have found it fixed the problem with the 0x745f2780 reference error.
Hope this helps! Good luck!
Sep 17, 2009 | Dell Microsoft Windows XP Home Edition
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
    services.msc
    REGSVR32 WUAPI.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
Svchost.exe problem
Turn off your computer and remove the cover. Ground yourself first and make sure no power plugs are still connected. Find your memory cards and remove them from the motherboard. Then reinsert them. Connect everything back and start the computer. If the problem still persists. Then your operating system is corrupted and you might have to re-install windows. I hope this helps.
Mar 03, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Svchost exe application location error instruction at 0x00d896bc
This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1 loadTOCNode(2, 'workaround'); Leave the svchost.exe - Application Error dialog box open, and then follow these steps. Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS) are correct loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, point to Run, type services.msc, and then click OK.
  2. In the details pane, locate and double-click Automatic Updates.
  3. Click the Log On tab.
  4. Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
  5. Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
  6. Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
  7. Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, click Run, type REGSVR32 WUAPI.DLL, and then press ENTER.
  2. When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
  3. Type the following commands in the Open box, one after the other, and then press ENTER after each command:
    REGSVR32 ATL.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder loadTOCNode(3, 'workaround'); The temporary folder of Windows Update may be corrupted. In this case, you can rename the temporary folder of Windows Update. To do this, follow these steps:
  1. Click Start, click Run, type cmd, and then press ENTER.
  2. At the command prompt, type net stop Wuauserv, and then press ENTER.
  3. Click Start, click Run, type %windir%, and then press ENTER.
  4. In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
  5. At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
uparrow.gifBack to the top Method 2 loadTOCNode(2, 'workaround'); Follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Automatic Updates tab.
  3. Click Turn off Automatic Updates, and then click OK.
  4. Restart the computer.
  5. Use the Windows Update Web site to install updates manually.
  6. After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
Dec 26, 2008 | Computers & Internet
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
