Question about First Alert FWS-101 Wireless RF Weather Station Clock Radio
My enviro station model DWS 150 keeps beeping every few minutes. I push the clear alarm button but it doesn't help. How can I stop it?
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Cannot delete alarm setting. It beeps every morning at 7:00 am
Look for an alarm button and see if the display indicates that the alarm is off. If no alarm button, you should toggle through the settings until you see the alarm settings. As you toggle through, the alarm should be turn off. For more help, please provide your manufacturer, make and model of what you need help with.
Mar 04, 2015 | Measuring Tools & Sensors
E039
Usually E0 39 or E 39 or 3 039 is mismatch between your new board and current boards. Do a reconfig: install new board. Plug in. If you get the 39 code push one of the burner on/off buttons to make the beeping stop and blank display. Then, push and hold right front and right rear UP buttons simultaneously until 88 appears in display. Then press and hold left rear and left front UP buttons until beep sounds and configuration starts. A few seconds later it should clear and be all set! Hope this helps.
/uploads/images/9_6_2014_11_25_49_pm.jpg
May 07, 2014 | Cooktops
How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Apr 18, 2012 | Freezers
I have an old maytag gas range model number CRG9700AAW, that beeps with an "F7" on the display, any idea what this alarm is?
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag Kitchen Ranges
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
First Alert FWS-101 Wireless RF Weather Station Clock Radio Logo
124 people viewed this question
Top First Alert Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a First Alert Audio Player and Recorder Expert? Answer questions, earn points and help others
