Question about Sharp SF 2020 Copier
I have a Sharp SF-2030 copier & I would like to disable sorter
There is a problem with the sorter & as this is not used I would like to remove it and disable this function. Can anyone help with this please.
    New Friend:
  • 91 Answers
Uninstall the sorter unit then you should go to simulation mode by entering these buttons :
C interrupt 0 interrupt ( less than 5 seconds ) 26 start 1 start then change the value to 0 and start
Good luck
Posted on Mar 13, 2009
How to check the meter
just push the 0 key or cancel key, just try you can read the counter
Jun 24, 2013 | Sharp SF-2025/2030 Copier Toner Black...
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
How do I clear error F1-00 on a Sharp copy machine SP 2040
That is sorter comunication problem .check sorter cable
Jun 30, 2010 | Sharp SF 2040 Copier
Sharp SF 2030: How do I clear code 115?
we don`t have code 115 in 2030 model .maybi it is H5 but your led doesn`t show.
May 18, 2010 | Office Equipment & Supplies
We have a Sharp SF 2020 copier - can we use it as a printer?There are no ethernet or usb ports on the copier. Is there a jet-lan type of card for it?
No( There are no Sharp SF 2200 Ethernet and USB- ports, There is no a jet-lan type card. sorry. For you any help((
Sharp 2020 Code Description CC Original detection problem CH Lit Steadily: Sorter not installed, or not turned on CH Flashing: DV unit not installed, not connected properly, or not latched in place properly F1 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive. F2 Sub code 31: Image density sensor. Could be a problem with light level. Sub code 32: Drum mark sensor problem. . Does not see mark on drum or sensor not working properly. H2 Sub code 00: Fuser thermistor open. H3 Sub code 00: Fuser temperature too high. H4 Sub code 00: Fuser temperature too low. Lamp, thermal switch, connections. L1 Scan forward problem. Motor, sensor, board L3 Scan forward problem. Motor, sensor, board. L4 Drive problem; main motor, gear, sensor, bind. L5 Lens problem. Motor sensor board. L8 Sub code 01: Zero cross. P Paper feed problem or no paper PC Card counter not installed U2 Sub code 01: Memory loss. U4 Sub code 00: Communication problem between copier and duplex unit. U5 Sub code 00: Communication problem between main board and ADF.
Mar 12, 2010 | Sharp SF 2020 Copier
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
Mar 24, 2009 | Sharp SF 2020 Copier
Sharp sf 2540 code F1
The F1 error code -- lost communication with the sorter. Are there secondary numbers after the F1?
Check connector cables on sorter and machine, check power to sorter. If those are fine then you are looking at a board problem. Also make sure that all covers are close properly. *** check cover between the sorter and machine*** ( you may have to pull sorter away from machine).
Jan 24, 2009 | Toshiba e-Studio65 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
180 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
