Question about Husqvarna 2012 Yth 24v48ls Lawn And Garden Riding Mower
Oil change yth24v48
Where is drain plug
Need assistance on changing oil and primary. Warrenty is out and doing it myself.
The oil drain plug is on the bottom of the transmission as the oil tank is located there. Usually the drain plug is the one closest to the left front of the pan. Drain the oil, change the filter, and add fresh oil. To change the primary, locate the small pipe plug on the bottom of the primary directly below the derby cover and remove it. Drain the oil, remove the derby cover, and stand the bike straight up. Fill the primary with oil just until it comes up the bottom of the outer clutch drum. Do not overfill. To change the transmission lubricant, locate the pipe plug on the front of the oil pan on the bottom of the transmission. Drain the oil and refill though the plug and dipstick in the chrome release cover on the right side of the transmission. Add 20-24 ounces of oil.
Good luck
Steve
Jun 05, 2011 | 2004 Harley Davidson FLHRCI Road King...
Do I need a mechnic for changing oil in my chevi
No. The oil is very easy to change. All you need is a filter wrench and a 15 mm. socket, and a drain pan. Get under the truck and the oil filter is right there and the drain plug is in the oil pan. Drain the oil first, then remove the oil filter with the filter wrench. Take your finger and dip it in the oil and put a film of oil on the new oil filter gasket. Then install the new oil filter. Once you install the new oil filter, put the drain plug back in. Then put 5 quarts of new oil in the oil fill.
Jan 11, 2011 | 1999 Chevrolet Silverado 1500
Change the oil on a 2000 Dodge Caravan
Jack up pass side.Put cardboard, BIG piece under engine just in case. Using a pan to drain the oil in put under oil pan drain plug. Remove drain plug with socket wrench. Let drain 5 min. Check the gasket on the drain plug, if bad replace with new gasket .99 cents to replace gasket only on plug. Put plug back in DO NOT OVER TIGHTEN the plug. Slide drain pan with drained oil to the front to remove oil filter. Using a filter wrench remove oil filter. Let drain. When installing new filter put a little new engine oil on the rubber gasket on the filter with your finger. Screw filter back on tighten with filter wrench. Fill van with oil from front valve cover opening.
Nov 21, 2009 | 2000 Dodge Caravan
How to change oil in 2003 HD FXD Dyna Super Glide
remove the drain plug from the oil pan, you will need either a 3/4" box wrench or a 5/8" box wrench and the drain plug will be facing forward on the the oil pan. It is easiest to remove this drain plug from under the right side of the bike. put drain plug back in after about 10 m,inutes of drain time and tighten to 18 ft. lbs. Dont forget to change the oil filter as well.
Oct 28, 2009 | 2003 Harley Davidson FXD Dyna Super Glide
Oil change
You owner's manual should tell you how to change the oil. On a Softail, the oil drain is a hose that runs from the oil tank down to the lowest part of the frame right behind the chrome cover on the end of the transmission on the right side of the bike. It has a "plug" in it. Loosen the clamp, pull the plug, and the oil will drain from the oil tank. While it's doing this, change the filter. Yeah, that's a messy job. Once the oil has drained out, replace the plug and refill the tank with the correct amount (3 quarts) of the correct oil (Harley Syn3 or equil).
Sep 25, 2009 | 2004 Harley Davidson FLSTC - FLSTCI...
How do I change the oil?
oil drain plug underneath engine usually on fill plug engine oil is stamped in oil stick.Do not over tighten drain plug when reinstalling
Apr 22, 2009 | 1997 Yamaha YZF 600 R thunder cat
Chang oil and care of filter of oil
How to change Oil>>
Step 1.
Put the bike and your tools in a convenient place. Raise the bike onto its kickstand in a clear area that can get a little dirty. Gather your new oil, tools, rags and drain pan in one place so you don't have to run to get a tool in the middle of the oil change.
Step 2.
Find the drain plug and filler cap. Before you begin to work, make sure the engine is not hot, though it should be slightly warm. Remove the filler cap so that the oil settles to the bottom of the can and can be properly drained.
Step 3.
Place your drain pan underneath the bike's drain plug. You can use a flat piece of metal, or even a piece of cardboard, to channel the oil into the drain pan.
Step 4.
Use a socket wrench to open the drain plug. Open the plug slowly so any built-up pressure can diffuse. Keep an eye on the oil's flow so you can catch as much of it as possible with the drain pan.
Step 5.
Change the oil filter. While this is not strictly necessary, it's a good idea to take the time to change the bike's oil filter. Locate the oil filter using the motorcycle's manual and replace it with a new one.
Step 6.
Replace the drain plug and refill the oil. Make sure the drain plug is securely fastened and then pour fresh oil into the tank, using the amount of oil that is specified by the bike's manual.
>>After 5000 kms you need to change the filter. Oil brand is a matter of preference as oil and filter is really a cheap price to pay so that your engine will last and last.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | 2007 Bajaj Discover DTS-I
Genral oil change
1.Get your supplies ready and expose your engine 2.Unscrew the Oil Filler Cap 3.Remove the Oil Drain Plug 4.Remove and Replace the Crush Washer 5.Clean the Oil Drain Plug 6.Remove the Oil Filter 7.Remove and Clean Plastic Mesh Filter 8.Lubricate the O-ring of the New Filter and Attach it to the Engine 9.Motorcycle Oil Change - Replace Oil Drain Plug & Plastic Mesh Filter Pour Oil 10.Check the Oil Level,,
Nov 10, 2008 | 2001 Mondial Piega
Genral oil change
Nov 10, 2008 | 2008 Bimota DB5S
Genral oil change
Nov 10, 2008 | 2005 Benelli TnT
Husqvarna 2012 Yth 24v48ls Lawn And Garden Riding Mower Logo
185 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
