Question about JVC SP-PW100 Subwoofer
Subwoofer parts My JVC subwoofer has stopped working due to power interruptions.The part not working is the transistor :"KC 2026 ". I need this part to enable my Home Theatre to start working again. The MODEL NUMBER is SP- PWC50 SYSTEM NUMBER TH - C50 SERIAL NUMBER 151Y3980 I hope you can help My email address is louisghassoub@yahoo.com.
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
  • 6 Answers
SOURCE: can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Posted on Jun 16, 2009
  • 2322 Answers
SOURCE: my jvc subwoofer inner speaker windings blow up
I would suggest to buy the entire cone speaker because the inner windings is harder to find or not available.
The cone speaker part number is: CR160058-01. Try contacting this website to find the cone speaker or you could find a cheaper speaker cone with the same dimensions and wattage.
I can also send you the service manual for this subwoofer.
Posted on Nov 27, 2010
  • 29 Answers
SOURCE: I had a jvc pwm508 home theatre system, the dvd
Yes you can do mr.
Posted on Dec 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: where do i find a
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Posted on Mar 16, 2011
Power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
Oct 19, 2011 | JVC AV-24F704 24" TV
HOW TO REPAIR A DAMAGED JBL PB12 it just stopped working, somebody told me it was unfixable due the part are very hard to get I guess the internal amplifier got broken
There is a quick way to find out if the parts are hard to get. Look inside a make a note of the IC and Transistor numbers. Don't bother with the resistors and caps. Put the numbers into Google and see what comes up.
Feb 08, 2010 | JBL PB12 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
Subwoofer stops working after about an hour's use. Authorized repair technician could find nothing wrong.
In case of a transistor which is faulty, could short the power supply in circuitry, and this happens after the transistor gets heated up. So you might wanna inspect the transistors on board to replace if found faulty.
--Sandy
May 30, 2009 | Audio Players & Recorders
Output stage bad
Only place for parts and service is Velodyne.
Oct 20, 2008 | Velodyne DLS-3500 Subwoofer
JVC receiver shows power, but won't turn on
Your receiver have a bad channel, maybe is a couple of damage
transistor.
Your need indentificate and change the transistors.
Dec 28, 2006 | JVC RX-9010V Receiver
Blinking Led power light
I have a alpine MRP-M350 700 watts class D... i will ask if it can support 2 subwoofer a 1200 watts 10" JBL subwoofer?
Aug 22, 2006 | Alpine MRP-M350 Car Audio Amplifier
JVC SP-PW100 Subwoofer Logo
297 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
