Lost connectivity to network printer when switched to ATT u-Verse
When I had ATT U-Verse installed, they use a 2Wire 3800HGV-B modem/router. When installed, I lost access to the printer connected to the PV hardwired to that modem from my laptop PC on a home wireless network. I previously had that access with the same physical set-up using an ATT DSL Modem and Linksys router. How can I it set-up so I have access to the printer through my laptop on the home wireless network ATT v-Verse help desk told me that don't provide support for this question...
  • BlairRW Apr 10, 2009
    When I had ATT U-Verse installed, they use a 2Wire 3800HGV-B modem/router. When installed, I lost access to the printer connected to the Computer hardwired to that modem from my laptop PC on a home wireless network. I also lost connections to all other computers in my home, wired and wireless. I previously had that access with the same physical set-up using an ATT DSL 2wire Modem/router. How can I it set-up so I have access to the printer through my laptop on the home wireless network ATT v-Verse help desk told me that don't provide support for this question. They referred me to ATT Connect Tech where they offered to help me only if I purchased a 6 month service contract for $175.00.
I don't know what kind of printer you have, but I had same problem with my wifi printer (epson)
Best think to do is reset your printer to factory default and then connect you printer with the u-verse modem/server network port and reinstall your software and you should be able to install the printer again. after successfully done this then you can disconnect your network cable and should work wireless.
Posted on Dec 16, 2009
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Posted on Jul 01, 2009
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Have ATT Uverse & it always drops the internet connection. I reset the main 2wire box weekly. The little router by my desktop is the problem - I have to disconnect & reconnect several times per...
check with 2wire website for a newer firmware version. if you are able to update to a newer version and still have problems, then your router is on its way out.
Aug 24, 2010 | 2wire (1000-400108-001) Router
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
Will a netopia 3-d reach wireless adapter work with my 2wire 3800hgv-b router from u-verse?
if you are wanting to run stricktly wireless then no if your router is not wireless ready. If it only has wired connections and not wireless capable you will have to be wired into it using a cable.
Oct 17, 2009 | 2wire HomePortal® 1800HW Router...
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
Want guests to be able to use our AT&T U-Verse broadband network.
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Computers & Internet Logo
2,511 people viewed this question
David Payne
David Payne
