Question about TJF Apps OBDII Trouble Code Lookup Lte
P1128 code dodge 2009 grand caravan - TJF Apps OBDII Trouble Code Lookup Lte
Both my keys FOBs on my 2000 Dodge Grand Caravan don't work, changed the batteries, still did not work. Bought 2 new ones and the dealer could not program them.
Programming a Replacement Keyless Entry Remote ' Filear ...
filear.com/?p=131
Oct 17, 2012 - If the transmitters don't work, or if you'd rather not match the transmitters yourself, .... Tried these instructions last night on my 2005 Grand Prix.
Key FOB Not Working - The Chrysler Minivan Fan Club Forums
forum.chryslerminivan.net/showthread.../11859-Key-FOB-Not-Working
Mar 15, 2009 - 10 posts - ‎3 authors
Hi Everyone, One of my Key FOB's stopped working. Is there a way of ... Well, to be honest, you don't know where that FOB has been? LOL ... 2009 Dodge Grand CaravanSXT (3.8L), Light Sandstone Metallic, 125K miles 2005 Volvo .... By jimmy154 in forum 3rd Generation Chrysler Minivans: 1996-2000.
Key May Not Start Car or Release From Ignition : Dodge ...
repairpal.com > Problems > Dodge > Grand Caravan
Dodge Grand Caravan Key May Not Start Car or Release From Ignition. ... If the newkey doesn't work, replacing the lock cylinder including tumblers ... I am able to turn off the van, but the key is stuck in the ACC position, draining my battery. ... In reading other comments, I see it may be the FOB so I'll carry both with me and ...
2009 Dodge Grand Caravan car lock doors not working
Jan 24, 2016 | 2000 Dodge Grand Caravan
Where is the turn signal flasher located in a 2009 dodge grand caravan
Front seating area, driver side, under dash, mounted in junction block ,front seating area,drivers side,under dash mounted in junction block.
Nov 09, 2014 | 2009 Dodge Grand Caravan
HOw do I reset the Gascap error message on my 2009 Dodge Grand Caravan?
if the problem has been fixed than the light will go out on its own after several drive cycles. Otherwise you can use a scan tool to clrar ghe code. You can also try disconnecting the battey but i would not recommend it as it can also reset other learned strategies that you dont want to reset. Once cleared if it comes back on than the ptoblem is still present and will need further test to solve and repair
Jun 25, 2014 | 2009 Dodge Grand Caravan
Replacing rear wiper arm on a 2009 dodge grand caravan
undo nut take oldone off and put new one on and tighten nut up
Nov 02, 2013 | 2009 Dodge Grand Caravan
Front wheels lock when turning in my 2009 dodge grand caravan
there is a tbi on dodge caravan and grand caravan for the front and rear brakes locking up . it is a recall if you are under 60,000 miles
Nov 03, 2012 | 2009 Dodge Grand Caravan
Dodge Grand Caravan 2009, warning sounds while turning. No lights on the dash and no warning messages.
The seat switch is sensitive and may be wearing out. The alarm dings when there is weight in the seat but seat belt is not fastened. The turn may have closed the failing seat switch.
Dec 15, 2017 | 2009 Dodge Grand Caravan
Reset oil light on a 2009 dodge grand caravan
Turn key to "on" position (don't start engine) press and release the gas pedal three times.
Feb 29, 2012 | 2009 Dodge Grand Caravan
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
2009 Dodge Grand Caravan - 14000 miles and the instrument panel light have gone out. Fuses are all pushed in. Any ideas?
check to make sure fuses are not blown if thats not it check the relay in the fuse panel
Dec 04, 2009 | 2009 Dodge Grand Caravan
My new 2009 dodge grand caravan keyless remote
RF interference. same bandwidth as there sat communications system. It happens. Hope this helps.
Aug 23, 2009 | Alarm & Keyless Entry System Dodge...
TJF Apps OBDII Trouble Code Lookup Lte Logo
150 people viewed this question
Top TJF Apps Apps Experts
Are you a TJF Apps App Expert? Answer questions, earn points and help others
