Question about Bushnell PinSeeker 1500 Tournament Edition Laser Rangefinder
New batteries, but does not show yardage when on
I have purchased new batteries. I focus on the pin, or other objects, but it apparently does not read the range. Not sure if it is laser not working or something else.
  • billwburger Mar 11, 2009
    I am sure the battery is working because the unit will focus on the object. It is a bushnell pinseeker 1500, which shows distance and slope of object. When I press the buttons, the circle appears on the screen for me to focus on the object I want distance to. This is why I think the battery is good.
    It appears to be working by taking out battery and resetting. appreciate
    Brigadier General:
  • 3,614 Answers
may i know exactly the model of the unit.
also make sure the battery was fully charged
Posted on Mar 11, 2009
  • micromaster
    micromaster Mar 11, 2009
    better to remove the and resit again the battery on =
My RB800C seems to have a battery problem...seems to always show low battery power and will give a yardage reading or two before refusing to work again. This AM I put a new battery in it and again it...
I struggled to work out what was going on with mine (I had the same problem) and concluded that it was either an issue with the electronics, which was beyond my skills to fix, or something much simpler. We all tend to assume the more complicated answer, so I focused on the very thin and nasty spring inside the battery housing cap. I wondered if that spring was deforming in some way and causing a short circuit. So a couple of months ago I unscrewed the two tiny retaining screws that hold the plate on which the spring sits, took the plate out, removed the spring, and replaced it with a much thicker, gold plated spring taken from a small flashlight I no longer had a use for. I soldered the spring into location on the plate, returned the plate to the battery housing cap, and inserted a new battery. Two months later, the battery is still showing full power.
Feb 04, 2011 | Leupold Wind River RB800C Rangefinder
I have the Bushnell yardage pro 450. It has a new battery and will not show yardage or it sometimes flutters the number but you can not read it. Sometimes it will show partial numbers!
I went to another website and read the reviews of other owners of Bushnell products, this is a common problem from Bushnell products. The fix is to buy another or try to get them to replace it, they should recall everyone of them and give refunds or new rangefinders. I found all this out for free, thank you very much!!!
Oct 21, 2009 | Bushnell Yardage Pro Sport 450 Laser...
Bushnell yardage Pro won't read distances. Short
Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
call 800.423.3537 and ask them
mtg
Oct 08, 2009 | Bushnell Yardage Pro 500 Rangefinder
When I aim at a given object it reads 1888, and cuts off.
I would advise calling bushnell customer service and send your unit in for repair. they can be reached by calling 800-423-3537 option 1. this unit will need to be sent in for repair.
Oct 06, 2009 | Bushnell Yardage Pro 500 Rangefinder
Digital range reading doesn't show clearly
It needs an alignment... IF not all the LCD segments are not working (hold down the power button) it will need more than likely a alignment and lcd. Hurry, they are starting not to do this service.(new models coming in)
Get in touch with them.........HURRY
MTG
Jun 17, 2009 | Bushnell Yardage Pro Sport Rangefinder
Tour v 2 , it doesnt show the actual yardage and I didn't try i
Make sure the battery is good. (Go to a radioshack and have them measure the voltage). It should be 3.1 to 3.2 volts. The reflectivity of objects being measured is a factor. Lighter colors reflect better than darker colors. Larger objects reflect better than small ones. License plates, highway signs are very reflective. You should be able to hit one of those from more than 700 yards away. Make sure the Pinseeker mode is on and try.....(touch the mode button and the flag comes up on the screen) Don't hold the mode button down for more than 5 sec or you will switch the unit to meters instead of yards.
Mar 24, 2009 | Bushnell Yardage Pro Tour Rangefinder
Bushnell 500 pro
it says in the manual that it will only read yardarges beyond 20-yards
Jun 29, 2008 | Bushnell Yardage Pro 500 Rangefinder
Pinseeker is blurred
There is an adjustment ring bewteen the eye piece and the body. Make sure the white ines are lined up and it should come back into focus.
Jun 17, 2008 | Bushnell PinSeeker 1500 20-5103...
New battery
I also have a dead Yardage Pro Tour XL. Would you be interested in selling me yours for a few bucks for parts? Thanks. genebaker@yahoo.com
Dec 07, 2006 | Bushnell Yardage Pro Tour XL Rangefinder
Bushnell PinSeeker 1500 Tournament Edition Laser Rangefinder Logo
178 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
