Question about Intel DX38BT Desktop Board (BLKDX38BT) Motherboard
Intel dx38bt red leds on and it doesnt turn on
I assamble a computer 2 monts ago with a motherboard dx38bt from intel, sudenly yesterday it turn off and is dead I dont know what happend, I have try to reset the eprom, check the power suply and everithing works fine, when the board is connected to the power two red leds are on the procesor led that indicates an elevated temperature on the processor, and the Voltage Regulator Led that indicates an elevated temperature in the processor voltage regulator circuit. And the computer it doesnt turn on. I dont know what else to do or if my processor or mother board is death
Red light on motherboard
check mobo manual and/or manufacturer support website for the exact meaning of this blinking light !!! Then proceed with faulty (or mismatched) component (mobo, cpu, mem ??? )
Feb 13, 2014 | Intel DQ57TM Executive Series Motherboard
DX38BT motherboard wirer hook up.
http://www.intel.com/support/motherboards/desktop/dx38bt/sb/CS-028327.htm
Click on the blue - English Product Guide [ PDF ]
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
Connecting to the Internal Headers
Page 50 for the PDF file page number. Figure 27. Internal Headers
The front of your computer is the Front panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Item I in Figure 27.
Detailed connections on Page 54.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | Systemax Venture PC Desktop
Desktop shuts down with no video
This would seem to indicate that the RAM or motherboard does not work correctly with the settings that you set. There should be a jumper on the motherboard for BIOS reset. Also most newer systems will automatically detect a problem and reset to defaults after 3-5 failed boot attempts. The most likely reason for only seeing 4GB would either be that you have 32-bit version of Windows 7 or that one stick of RAM is bad. To see and use more than 4GB of RAM you need to have a 64 bit operating system.
Feb 17, 2012 | Intel DX38BT Desktop Board (BLKDX38BT)...
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Sir i have Intel D102GGC2 Desktop Board. I'm buying 2 years ago. Now I'm problem is System Power on but not Display problem. Help me please.
if the cpu fan running and the hardisk led turn on the problem might in memory or processor. did you hear the beep?
Nov 22, 2010 | Intel D102GGC2 Motherboard
My system doesnt start
if no beeps (remove the RAM and for sure has to beep if the motherboard is OK) at all and no video signal you may look to:
1. a new PS - power supply or
2. a new CPU or
3. a new motherboard.
Jan 10, 2009 | Intel (SL5TL) Pentium 4, 2 GHz Processor
DX38BT
did you install the heatsink with thermal compound before installing windows?
Sep 27, 2008 | Intel DX38BT Desktop Board (BLKDX38BT)...
No display
hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Jun 10, 2008 | Gateway GT5028 PC Desktop
Intel DX38BT Desktop Board (BLKDX38BT) Motherboard Logo
181 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
