Related Tags:
This problem should be removed because:
Problem with Hayward Viper with Booster Pump
Hayward Viper 5500 is spinning in circles
The sweeper is spinning in tight circles, causing the cord to get tangled in about 2 minutes
Solutions (3)
Best Solution
We found the problem to be a faulty check valve. the check valve cost about 25.00. I ordered it from poolcenter.com. The check valve is located by the cam. It's an easy fix. The check valve comes with the hose attachment, but since our hose was ok we just used a tie strap to connect the new check valve to the hose...sliped back into place... and it works like a charm once again. The part number is below. go to www.poolcenter.com
HAYWARD VIPER CHECK VALVE W/ HOSE & TIES - AX5000CVA
I had the same problem. I took the sweep motor apart and used a scotch brite pad and smooted the inside of the piston that operates the spinout. I also lubed the o-ring seals with some vaseline before putting it back together. I also used the scotch brite pad on the little plastic part and its mating surface the piston operates.
Yes my attachment to the cleaner spits water out of it thus not really moving properly!! Is this a common problem...
Runs in a small circle
I have a Ray Vac - concrete that runs in a small circle in a 40' 20 Gunite pool. Even though it reverses direction via the hydro...
Pondmaster Mag Pump 1200 gpm has electrical short.
Pondmaster Mag Pump 1200 gpm has electrical short. When the cord at the pump is moved the pump goes off and on. Can I repair this? (i.e....
Ray Vac Pool Cleaner for Inground Concrete: after...
After cleaning out debris from my ray vac my jandy still goes in circle
Ray Vac Pool Cleaner for Inground Concrete: Our...
Our Ray vac worked well for years but now it tends to go in circles and get tangled up. What can we do about this?
Add Your Solution
My Hayward Viper pool cleaner
My Hayward Viper pool cleaner just spins and spins, tangling the hose and not moving around the pool. I've changed...
Fix-O-Meter
1,568
1,568 people viewed this problem
- 9 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Hayward Pond and Water Garden Supply Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
