Question about Lexmark E460DN/E460DW CTLRFORMS BAR CODE CARD (0034S0970)
Gives a loud clicking noise when printing
The printer gives out loud noise during printing
3 Suggested Answers
  • 4 Answers
SOURCE: lexmark T520 laser printer has loud siren noise
Does it sound kinda like a jet engine revving up? If so then the printhead may be going bad.
Posted on Jul 15, 2009
Printtech
  • 1087 Answers
SOURCE: printer making a loud clicking noise...was
Can you tell us which light on the modem has a solid orange light? The operator panel lights mean different things, depending on their sequence. Please tell us more about it so that we can assist with your issue.
For further assistance, please contact Lexmark Technical Support.
Posted on Jul 18, 2011
Changed the ink cartridge and the drum, now it makes the loud clicking noise during printing
remove the toner cartridge if you can and shake thoroughly, then try putting it back in.
Apr 23, 2015 | Sharp AL-1655CS Laser Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Changed the ink cartridge and drum. now it makes this loud clicking noise during printing
hope you removed all the packing material from the drum before you installed it.
Apr 23, 2015 | Sharp AL-1655CS Digital Laser Copier...
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Lexmark T520 laser printer has loud siren noise
Jun 16, 2009 | Lexmark T520 Laser Printer
VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Lexmark E460DN/E460DW CTLRFORMS BAR CODE CARD (0034S0970) Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
