Question about Amana SXD524VW Side by Side Refrigerator
Amana afd253des not cooling - Amana SXD524VW Side by Side Refrigerator
Amana bottom freezer/frige not cooling. Clicking sound then buzzing sounds and clicks off. Compressor hot. Hear it running but no cooling.
Solution to this recyle-Amana is to scrap it and get a "GOOD" brand!!
The condenser/compressor is made by Tucumsah, excuse the spelling, but you know what I'm saying.
Jan 15, 2013 | Amana ABB1927DE Bottom Freezer...
My amana refrigerator is not cooling, freezer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Have a 17yr old amana energy saver frig. freezer on bottom. freezer works fine, but no cooling in refrig.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Amana Refrigerators
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Amana SQD25VL coils cool, but deepfreeze fan does not engage
Sounds like a bad fan motor. Be sure power is getting to it.
Dec 01, 2009 | Amana Freezers
Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
No cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Jul 02, 2009 | Amana Heating & Cooling
Need to know what the settings are for the range adjustment A,B,C,D slide switch on the front panel on a Amana PTH123A35AC PTAC
Here they are;
Position A, Cool 70-78, Heat 65-73
Position B, Cool 68-81, Heat 68-76
Position C, Cool 66-83, Heat 61-78
Position D, Cool 63-88, Heat 58-83
Amana calls this a Temerature Limiter and says to only set one switch on at a time. If all switches are off then the unit is at full operating range.
Please rate this answer to let me know if it was the fix.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
