Question about Lexmark X1270 All-In-One InkJet Printer
Printer not Commuicating with Computer
After the installation, I can Scan and but when I try to print something, I get a error msg indication Printer not communication with Computer, I checked the USB cable, Power cable, disconnected and reconnectedand Re-Started the computer. I noticed that when the printer on 'On' and I am restarting my computer, the light on the printer does not go out. I have a Lexmark 515 but it is not a Scanner nor Fax but when I use the printer and have to re-start my computer for some reason, I notice that the light on the printer goes out (Printer turns off) when re-booting the system.
  • Ceegie Mar 11, 2009
    I tried adding a new USB cable and power plug, and re-started my computer. I still get the same msg. Printer not communicating with computer.
  • 4,889 Answers
Greetings Ceegee,
The problem is not with the printer, scanner or the computer. A few days ago, I had the same issue on my comp a message popped up telling me "Twain error!Unable to initialize the device due to a communication error. I have un-installed every thing including the driver and the software and then reinstalled and that has resolved the issue. It should probably work with yours too. Iff you don't have the CD to do it you can get the driver and software from here
If it still doesn;t resolve the issue, then I have read an article on the lexark support site that says
"An issue was recently discovered with some internet security packages and the listed Lexmark printers. The issue turned out to be with the "Parental Controls" module of the packages.
NOTE:
Most 2008 versions of internet security packages do not have this issue.
What to do
  1. Use Add/Remove Programs to remove the Parental Controls module.
  2. If this option is not available, remove the internet security package (ISP) completely. For additional information or a product update, please contact your ISP providers. ISP providers offer a free download to their customers."
Source: http://support.lexmark.com/perl/support/support.cgi
Postback if this doesn't resolve this issue, and accept the solution if it does.
Hope that helps,
Sai.
Posted on Mar 11, 2009
  • 54 Answers
Hi Ceegie,
That is a driver issue, download the latest drivers for your printer here in the option "Search by model" type X1270 and press enter.
In the thex step select your language and Operating system or just scroll all the way down and clic on the tab of operating system of your choice.
Download and install the file, is recomended to unplug the USB cable during the installation.
Good Luck and thanks for using Fixya!
  • 477 Answers
Hello.
what OS does you use?
and you should try the postscript driver instead of the pcl5 driver. you should find it in the same package that you downloaded for your drivers. or your driver cd.
If you unplug the usb cable and then plugin again does your computer notice?
  • 6,784 Answers
Try unplugging the printer for 5 minutes. this will fix the firmware scramble.
  • Michael Masters
    Michael Masters Mar 11, 2009
    unplug from the power source for 5 min.
    Top Expert:
  • Lexmark Master
  • 78,267 Answers
HAVE U GONE TO THE LEXMARK USA WEB SITE SUPPORT SECTION AND DOWN LOADED THE LATEST SOFTWARE? HAD THIS SAME ISSUE, DID SOFTWARE UPDATE AND IT WAS FIXED.
    Genius:
  • 1,239 Answers
Hi try an NVRAM reset,, To do an NVRAM Reset:
CAUTION Only perform the following procedure if absolutely necessary. Performing an
NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a
default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
œ All menu settings to factory default values
œ Factory settings such as formatter number, page counts, and factory paper settings
Use the following procedure to perform an NVRAM initialization.
1. Turn the printer off.
2. Press and hold down the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 20 seconds. During this
process, the Go button, Attention, and Ready LEDs each turn on.
4. Release the Go button.
The printer lights begin cycling. After the NVRAM initialization is complete, the printer returns to the
ready state.
and now check it i think now it will be working,,, thank u,,,,,,,
  • ABHISHEK.C
    ABHISHEK.C Mar 11, 2009
    first try this one because if There was a 'problem communicating with the printer'This  indicates a network error.  Ensure that you are properly logged onto the computer.  (click StartMenu, above shut-down it should say logoff username. if it just says logoff, you're not connected to the network).  Check and make sure that the printer is on and that the printer is online.  On the hp's it says Ready. (if it says offline, press the go button)
    thank u......
  • 523 Answers
You problem is with printer driver, uninstall and install the driver back, unplug the printer cable and then plug it back check if your computer makes the sound that recognize it, if yeah look for driver and check it. if u were printing before and then it stops make sure u donot have any old documents stucking in your queue, delete them , put the main buttom for the machine off then on and try again.
Best Regards
  • Kyocera HP Expert Mar 11, 2009
    when you unplug the cable and plug it back if your computer doesnot give any sound that means cable problem.
    Genius:
  • 1,550 Answers
Try with different cable it will be due to defective cable you face this problem.
  • SAM ANDERSON Mar 11, 2009
    Better uninstall the printer driver file from the system and download from the lexmark website .
    To uninstall go to control panel ->add/remove program ->remove the driver file for printer .
    To download driver click the link below
    http://downloads.lexmark.com/perl/downlo...
    Follow the instruction there to download the drive
When I try to scan, I get an error msg that says "printer is busy."
Check your printer to see if you have any printing jobs in queue;
if so, clear them out and try again.
Oct 21, 2013 | Lexmark Impact S305 Wireless All-in-One...
Not printing after paper jam
Try the HP website. I just downloaded a tool that fixed my problem which was with a 1410 that worked with a Mac and with XP, but not Vista (although it had in the past). Print jobs showed in the queue, there was no error msg, but wouldn't print, either.
Oct 21, 2011 | HP PSC 1410 All-In-One InkJet Printer
Scan was not successful
Try a new USB cable. Directly connect the printer to the computer if using a hub or print server. Try plugging the unit into a different USB port. Scanners require bi-directional communication with the computer and are much more sensitive to anything that may interfere with that communication.
Do you hear any sounds that indicate that the light source is warming up and moving in the unit? Check if the scanner has a travel/shipping lock and unlock it. If it isn't moving, then you may need to service the unit.
I hope this helps.
Apr 02, 2010 | Lexmark X9350 All-In-One InkJet Printer
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
Scanner not performing properly
Here’s a GEEK-steer …
"...I recently had verizon fios installed, perhaps this is the problem?" ... did you start receiving error(s) immediately upon the very next use(s) after the FIOS install? If so, then that's an indication it's related. If not, just the opposite is true.
What's the verbatim (exact) error msg you're receiving, and what action(s) (scan, print, opening/launching something, etc.) precede it? Is your ScanJet working otherwise despite this error msg?
With answers to these questions, a readily apparent solution may present itself. Otherwise …
If problem persists, best course of action is to uninstall, then reinstall the printer software. Please refer to a previous post of mine http://www.fixya.com/support/t1382866-printer_works_but_will_not_scan and follow the applicable portion concerning the uninstall/reinstall procedure.
Please post back with clarification (for possible easier remedy than uninstall/reinstall), success/failure update, or any further questions you might have.
Good luck.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | HP Office Equipment & Supplies
Error msg 2--will not print
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I am using visita when i try to print i get msg save file but i dont want to save just print so it will not let me print even if i save still msg come back no permiision or something like this and do not...
Check to see if you have your printer installed correctly with vista drivers and also make sure that the printer is the default device for printing
Feb 12, 2008 | Computers & Internet
Lexmark X1270 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
