Question about Emerson (025806803716) Wine Cooler
I have an emerson wine cooler (8bottle) and the temp is staying at 63 when i click the temp down it flashes 46 but returns to the higher temp. it is about 3 yrs old
  • 3 Answers
SOURCE: Emerson wine cooler /ER2352
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
terrencio
  • 20 Answers
SOURCE: My 18 bottle wine cooler is less than a year old
Without the fan it won't pass the proper airflow accross the coil, the fan needs to be replaced.
Posted on Sep 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
  • 11800 Answers
SOURCE: I have an emerson fr24sl
The flashing signals that the thermoelectric element - the on that does the cooling - is no longer operational or the wiring between it and the control board has failed. To find out which you must open the cover on the control board and test them with a ohmmeter. Since the replacement parts are very hard to obtain by an regular person it would be better to take it to a repair shop.
Posted on Oct 11, 2010
What is the lowest temp that the cooler has.
If you got this new, You should have a manual with the hi-est and lowest temp setting in it...If you do not have the manual than you can Google the same question on google search and get a manual,or a forum where they talk about this model.
Mar 07, 2011 | Emerson (025806803716) Wine Cooler
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
2. Run capacitor
3. Temp control
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Emerson (025806803716) Wine Cooler Logo
120 people viewed this question
Top Emerson Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
