Question about Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170
How do you reset timer for vista mt 300
Need to set clock on this timer, also need to set on time and off time
  • Vista Master
  • 5,089 Answers
Check for same-similar timer on following link, and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Posted on May 12, 2015
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
I have a 7-day timer model em0101 and can't set it
That timer is not identified:
Copy following link to see variety of timers that might match your timer, and then download same-similar manual:
Jun 15, 2012 | Timex Hardware & Accessories
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
How do I reset my DTC Digital Timer for the Vista Outdoor Lighting sytem?
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Hamilton
The reset button is small round button with R
I assume you push reset button with toothpick
The manual is unclear if you need to press another button at same time to reset timer
Manual says: If needed, pressing "R" will cancel the current setting,
pressing "R" a second time will undo the change.
Mar 26, 2011 | Vista Pro Digital 7-day Electronic Timer...
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
How do you set the timer on Malibu 300 watt transformer, ML300RTW. I have the pins in the right spots, but the timer doesn't go around. I there a on/off switch to activate the unit?
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
Jul 01, 2009 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Apr 27, 2009 | Taylor Dual Event Mechanical Timer, 00521
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
Dec 30, 2007 | Miele Novotronic H350-2B Electric Single...
Vista Pro Digital 7-day Electronic Timer Dtc-170 Dtc170 Logo
409 people viewed this question
Top Vista Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Vista Hardware and Accessory Expert? Answer questions, earn points and help others
