Bios not recognising USB Devices
No usb devices working.
XP reports usb mice & flash drives as unknown devices when booted in Linux same thing.
My bios Phoenix NoteBios 4.0 release 6.1 06/06/2007 was able to boot from usb flash drives and depending on what make usb drive it appeared under HDD or FDD. legacy USB is enabled
Motherboard shows up as a ATI Bonefish with
ATI IPX 450 SB450
North Bridge ATI RS400 / RC400 / RC410
CPU Intel Core Duo T2250 533mhz socket 479 fsb 2gb ram DDR2 3x usb ports
Radeon Xpress 200 for Intel
Marked on motherboard it shows Hannstar J MV-4 94V-0 0716
model Sahara AL-096 Sahara purchased in SouthAfrica 15.4 lcd
Bios reports as Phoenix Bios Q3B71
also shows sub system as Quanta Computer Inc
this looks very similar to some Avent laptops in UK.
If device manager shows a conflict on the resources tab of ati smbus I\O range then the mobo is faulty and there is no fix other than a new mobo
Posted on Oct 17, 2013
  • 77 Answers
The only thing i can suggest is that should try and update your BIOS.. Check your manufacturers website and see if there is a BIOS update avaible for your computer
Posted on Mar 11, 2009
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
Flash bios lenovo 3099-1uu
It sounds like your hard drive may have failed. I would suggest the following to confirm.
  • At the splash screen, press F1 for BIOS Setup Utility.
  • Ensure that you see HDD and that it has a device id next to it
If you can see it, then you may have an operating system boot issue. If you cant see it then it might be an idea to remove the HDD and re-seat it. There may also be a setting in the bios for booting from an older operating systems such as XP. I think it might be a setting similar to "Boot mode set to UEFI" etc.
Another good tool to check hardware and get a device booting that may be missing the boot files etc, is to use an application called HIRENS. It can be put onto a USB stick. You can also do a hard drive test with it
The link is
To be honest I don't believe a bios update will do anything for you. But you could try loading the default settings etc.
I hope this helps
Nov 24, 2017 | Lenovo Computers & Internet
Usb boot
Start your PC and press F2 several times until the Bios menu comes up. Then select boot order or bootable device options and allow for usb devices to boot. Make sure the USB device in the boot order is moved to be in front of the HDD so it checks for it first and thus will load your linux distro from your usb drive.
Jun 25, 2012 | Fujitsu Siemens Fujitsu St-5010 St-5010d...
My 3660 does not recognise my DVD/CD write/rewrite theough the connections are all fine. Same too with my new Sony Walkman when plugged into any of my USB drives
Do any devices work in any USB ports on that laptop (Flash drive, mouse/wireless mouse, USB keyboard)?
USB support may be disabled in the BIOS.
Boot into the BIOS and check the built-ins and enable, if necessary.
(just in case, disable and then enable)
USB controller driver messed up:
Right-click [My Computer]
[Device Manager]
Look for any "marked" errors on devices
open the +USB Serial Bus Controllers
Pick a faulty one and "disable" then "enable" it.
If it still fails, then "Uninstall" it (Windows will find it and re-install it automatically.
That should do it.
Sep 22, 2009 | Acer Computers & Internet
WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Sep 15, 2009 | Western Digital Elements powered by WD 320...
Can't enable boot devices on ASUS eee 900 netbook
For less hassle you can install ubuntu within windows and it will work perfectly if your windows is operational...
Aug 19, 2009 | ASUS Eee PC 900 PC Notebook
I don't think this is possible. Still we can work on this.
Even I am verymuch Intersted with these kind of issues. I haven't tried installing XP on USB flash drive. But I installed the XP on USB harddrive and it worked.
We can try this with your co-operation. To boot with the USB devices, first your computer or laptop should have the option to boot with the USB devices. You can check in BIOS, under BOOT order for this option.
If USB boot option is not there, then you cannot boot with the Flash drive, not only flash drive all USB devices. They will work only after booting into Windows.
Comming to installation procedure, installtion is same as installing the XP on harddrive. While installing the XP, at partition page, you can see the USB flash drive, select it and continue the installtion.
If your computer has the option to boot with the USB devices and if the flash drive won't boot into Windows after installtion, then we have to set Flash drive as Active partition from Disk Management, and then we can try. In Disk Management, right click on the USB drive and select set active partition. If it won't allow to set the USb flash drive as active, then it is not possible to install XP on flash drive.
Even I googled everywhere on how to do this, but not information.
Try that and let me know the status. But I am sure, it is possible on Pocket drivers or USB harddrives.
Aug 09, 2008 | Computers & Internet
USB port problems
Try going into the BIOS and see if the USB Ports are enabled. I don't know what type of system you have. When you turn on the pc it will prompt 'F1 to enter setup' or it might be F10. Do you have a USB mouse or keyboard? Try those in different ports.
Computers & Internet Logo
1,489 people viewed this question
David Payne
David Payne
