Question about Golds Gym POWERSPIN 230 R Console
Plugged in the wrong power cord display won't show
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Cobra 25 lx shuts down when pluged in then won't power up
sounds like a thermal problem to me . Check out the reverse polarity diode first to see if its shows signs of being burnt . then take it to a tech and let him fix it.
Sep 02, 2012 | Cobra Radio Communications
Can't plug 400watt ballast into a digital timer,bulb won't light.
How did you connect the 2 cords if they don't match up ? Usually the cord configuration on just about anything electrical is for a reason . It is to keep from plugging inthe wrong things ! It is possible that your digital ballst won't run your fixture due to miss matched intternal parts . One may be magnetic and one digital electronic .
Aug 23, 2012 | Garden
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Golds Gym POWERSPIN 230 R Console Logo
64 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
