Question about Garden
Remove front tires/Dixon ZTR 4423
My two front tires are flat, and won't take air (while on). But, I can't figure out how to take them off! Help!
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
  • 61 Answers
SOURCE: where on the Dixon ztr 5421 do you check the
there should be a sight glass or a dip stick in the
hydraulic tank.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: Dixon ztr 311 The left lever will not make the
The motion drive design is similar to a set of spider gears, except it uses friction material rather than bevel gears in the cluster. The friction material may be worn down to the point that it no longer engages and needs replacement. This is a likely scenario for the symptoms you describe.
The replacement procedure is a rather involved process. If you feel confident and are VERY handy, reply to this post and I'll be happy to go into detail.
Hope this helps!
Posted on Oct 01, 2009
Testimonial: "Thanks, lots of help. Details would be great"
  • 20 Answers
SOURCE: what the air pressure in front tires on a cub
check the side of the tires . it will tell you. szm230
Posted on Apr 15, 2011
  • 3072 Answers
SOURCE: I have a Dixon 44/22
http://www.jackssmallengines.com/pdf_documents/Dixon/422_owners_manual_1981-1982.pdf
Posted on May 08, 2011
How do I change the tire on my Dixon riding lawn mower?
There is a special tool to remove the E-Clip. I tried it one time before got the tool and bent the clip. The tool is worth it to get the clip on and off.
Jan 17, 2016 | Garden
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Belt pattern for blade drive belt on Dixon ZTR6022
Try googling for the owners manual to view that
Oct 04, 2014 | Garden
Need a belt diagram for a dixon ztr 5023
Dixon 5000 Series Belt Diagram
Jul 21, 2014 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
Garden Logo
361 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
