Have a beko 6kg WM6143B and it intermittently makes a loud rattling noise, not necessarily when the drum is turning. Any ideas?
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
  • 236 Answers
SOURCE: Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Posted on Jun 01, 2007
  • 31 Answers
SOURCE: Loud rattling noise
the heat shield on the exhaust manifold
Posted on Aug 02, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
Is it worth getting my Beko tumble dryer fixed?
of course only 2 years old it should be .
Mar 12, 2015 | Dryers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
I have a Beko Electric Cooker, The oven is making intermittent rattling noises, which i think is the fan? How easy is it solve.
some models are acsessed inside the oven if you open the door and can see screws at the rear of the oven youre in luck otherwise it remove the rear cover of the oven and do it from there
Nov 13, 2013 | Ovens
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Beko DRCS68 condensor dryer is making loud vibration noises
hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic sound...it may also be the rear bearing these tend to eventually rund dry and fail..
regards Sir GalAHAD
Apr 17, 2009 | Frigidaire GLER331A Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Making loud rattling noise
yeah the problem is is the bearings have gone you can check this by placing the palm of your hand on the front of the washer and place your fingers into the inner drum and try and lift the inner drum upwards if it moves then the bearings are gone and this is an exspensive job you have to take the complete drum out split it cheaper to replace m8 let me know if this helps if not ill help you more into it
Nov 15, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
