Question about Home Security
How will i replace fai security guard sgII battery
3 Suggested Answers
  • 8 Answers
SOURCE: replacement system battery
First you have to open the front cover. There is a tab at the top of the unit you press in and the front cover opens. Then at the top of the face near the middle you will see a place you can insert a small flat tip screwdriver and press lightly to open the second cover. This will open the area for the back up battery and you can just take it out and get replaced. I would advise the monitoring company that you are going to do so in case they have a tamper alert or trouble alert from opening the second cover and batter. When you first open the front cover you might need to enter your user code to silence the beeps using the red numbered keys on the face plate.
Posted on Dec 04, 2013
  • 11 Answers
System was made by Ness under contract for FAI
nesscorporation.com
da933632-848e-4a17-8c7c-944248394fce.jpg31e29a4f-9542-4b61-9d54-b08e87369ba8.jpg4de89c18-7988-4a01-b3ee-c72dc366a411.jpgcebd0740-e05f-4148-81e0-8b32eff9fb4c.jpg240bcf98-ff5f-4fce-bae4-2e89a6ae8821.jpg8f853332-f412-478e-b36b-b9fd3648da13.jpg73fdb8c7-0337-4d45-bf13-541d0628f16a.jpg
d6569589-0a7b-48e4-9f27-906ddf528c3b.jpg052cc688-e96d-4113-99a5-4319ecd6203d.jpgf82ace49-2a00-4a4c-9fe9-ecbe56cdffe5.jpg7fa51c92-19c1-48ba-92b0-cd3d6e6175bf.jpg
Posted on Dec 15, 2013
What is Security Guard?
A security guard is the private people who are hired to protect the employing party's assets from a variety of hazards by using preventative measures. The security guard patrol system purpose is to provide help the companies monitor their guard tours without getting distracted from their initial cause: ensure the high-security level of their staff and guaranteed protection of buildings and assets. Guardso is always excited to add new features to make it work best for our customers.
Jul 26, 2017 | Cell Phones
How do I keep my sgii note from downloading apps when I restart it
First, goto google play store.
Then, press the menu button in the top left hand corner, which will open the left hand menu.
Select settings and where it says auto-update apps, select do not autoupdate apps.
Sep 06, 2014 | Cell Phones
Battery replacement
battery replacement, turn over keyboard you will see a door to remove, on the mouse the cover slides off look for arrows
Dec 03, 2013 | Computers & Internet
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
Need procedure to remove and replace the battery in a 2006 PT Cruiser
BATTERY
GASOLINE ENGINE
REMOVAL
WARNING:
  • TO PROTECT THE HANDS FROM BATTERY ACID, A SUITABLE PAIR OF HEAVY DUTY RUBBER GLOVES SHOULD BE WORN WHEN REMOVING OR SERVICING A BATTERY. SAFETY GLASSES ALSO SHOULD BE WORN.
  • REMOVE METALLIC JEWELRY TO AVOID INJURY BY ACCIDENTAL ARCING OF BATTERY CURRENT
  1. Make sure ignition switch is in OFF position and all accessories are OFF.
  2. Open hood.
  3. Remove the air cleaner housing.
  4. Disconnect and isolate the battery negative cable then the positive cable.
  5. Loosen bolt (4) and retainer (1) that holds the battery down to the tray.
  6. Lift battery out of battery tray and remove from vehicle.
  7. Remove thermal guard (if equipped) from battery.
CAUTION: Vehicles equipped with the turbocharged engine use a unique battery hold down. If the replacement battery is not identical, in size to the original, it may be necessary to use non-corrosive spacers on top of the hold down retainer to properly secure the battery in the battery tray.
When replacing battery, the thermal guard MUST be transferred to the new battery (if equipped).
  1. Install battery in vehicle making sure that the thermal guard (if equipped) is present and battery is properly positioned on battery tray.
  2. Install battery hold down hardware (1), (2), (3) and (4) making sure that it is properly positioned on battery. Torque clamp to 12.5 N.m (110 in. lbs.) .
  3. Install battery cables on battery posts. Install battery positive cable first.
  4. Torque clamp nuts to 12.5 N.m (110 in. lbs.) .
  5. Install air cleaner housing.
  6. Close hood.
  7. Verify proper vehicle operation.
Jul 15, 2010 | 2006 Chrysler PT Cruiser
Do you have a diagram on how to open my FAi security system box to change the main battery it it the model that runs on battery only plugs in the bottom, siren up the top digital display and sensor at the...
if you open case, probably have 2 to 3 hours of continuing siren on. this a protection switch who alarm firesup evan is in off mode, there a screw on case, to close all, but has security switch. you must open
Feb 21, 2010 | Heartland Door Stop Burglar Alarm - 118db
I replaced my battery in one of my remotes the system doesn't recongize the remote? Crime guard 328
reprogram remote. turn key to position, push valet button 5 times and then push the lock button on remote
Feb 01, 2010 | 119 Remote Replacement - i2/i3/i4 Series...
Home Security Logo
175 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
