Question about Nintendo DS Console
Ds randomly switches off
My old version nintendo ds randomly turns off and the sound only works very occaisionly. when playing gba games the random switch off is not a problem but the sound still does not work. this is very annoying for me. can anyoe help?
  • 89 Answers
Charge the ds.
Posted on Aug 05, 2009
  • 23 Answers
Its called repair man you should visit him some time
Posted on Jun 08, 2009
4 Suggested Answers
SOURCE: nintendo ds games not working
With three boys we frequently have this problem and we found that rubbing the pins clean with a Qtip dipped in rubbing alcohol and then wait for it to be mostly dry before re-inserting. Some times we have to do this 2 times  - good luck!
Posted on Jan 30, 2008
SOURCE: Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Posted on Apr 20, 2008
winwinwe
  • 28 Answers
SOURCE: Nintendo DS lite won't play nintendo games!!!
You can't produce a code out of mid air............
Posted on Jan 01, 2009
Do DS plays GBA games ?
Yes, but only on DS/DS Lite. There is a small panel at the front of the console on the bottom. Open it up and there is a slot. You may need to blow a little in it. Then on the menu, press a certain button (Sorry, can't remember what it says) and it will say something along the lines of 'Play GBA game'. Simply insert your game and press the button. Hope this helps.
Good Luck, and Game On!
Sep 17, 2009 | Nintendo DS Lite Console
I can't download pokemon diamond for gba
do you mean migrate pokemon from a gba pokemon game to diamond because if you do that you need to complete the sinnoh pokedex by seeing every pokemon in the sinnoh pokedex and then you can go to the pal park. Then put the gba game in the gba slot. Start up you diamond and on the menu there should be a sign that says, "Migrate from gba game"
Aug 21, 2009 | Nintendo Pokemon Diamond for DS
My games freezes at random times and messes up my ds lite
I do not think it would be a virus at all just a unlucky cartridge. They have something like a 0.05% fail rate when being made last check - That or it was pirated either way it is the game and not your consoles and I am unaware of a solution apart from buying a new game
Jan 03, 2009 | Nintendo Pokemon Emerald for Game Boy...
How can I play a Game Boy Advance SP game in a Nintendo DS???
Downloaded Game Boy games from the internet on your computer can not be played on a DS.
Dec 01, 2008 | Prima Codes & Cheats: Spring 2005 Edition ...
Nintendo ds problem
it may be a technical difficulty in the gba slot try bowing in it or get a q tip and kinda dust it out or blow in the game becuse the game isint making any connections to the ds and with the charger thing if u push in the charger too hard you might mess up the reciving thing inside the ds so it wont get the charge so be very careful when it comes to ds.....if u have any more questions plz let me know
Oct 25, 2008 | Nintendo DS Lite Console
Nintendo DS Lite
Try getting the latest version of the firmware for ur ds. After u download the firmware, put ur card into card reader. Use computer to delete everything except ur games. Then put the firmware that you downloaded into the card. See if it works.
Aug 30, 2008 | Nintendo DS Lite Console
Gba game wont work
Did you remove the cartridge with the DS switched on? This may have damaged the game. Is the DS still ok with other games?
Aug 02, 2008 | Nintendo DS Lite Console
Nintendo DS message... "Unable to load data. Turn the power off and resinsert the Game Card."
Well maybe when you turn it on, it might be on manual mode. To switch it to auto mode, Press options then press the wrench and then find auto or manual mode and then, switch it to auto mode. Save the options and then it should play the game. If it doesn't work, blow into the DS game and then the DS game slot.
Jun 03, 2007 | Nintendo DS Console
Will not play SP games
Did you clean the contacts on the game as well as the system? You may also try setting the GBA back to it's factory settings by turning it on and holding down L,R,A,B and Start
Sep 09, 2006 | Nintendo Game Boy Advance SP Console
Nintendo DS Console Logo
96 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
