Question about FAIP Garden
Faip model H120 doesn't shut off - FAIP Garden
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
The contacts on the microswitch have probably eroded a bit with age. The simple fix is to remove the red cover and adjust the setscrew that hits the microswitch plunger. Loosen the locknut and use an allen wrench to adjust the set screw. If you aren't sure which to adjust, power up the washer and pull the trigger while watching the motor assy. You'll see an arm moving outward when the trigger is released and in when you pull it. Follow this arm to the adjusting screw. Had the same problem with mine and had to move the screw OUT a half turn.
Hope this helps.
Posted on Oct 12, 2013
SOURCE:
How to set a high pressure unloader valve on a FAIP 1500 H120 washer
Are you talking about the electric switch that shuts off the motor when the trigger is released?
If so, there is an arm that comes out of the high pressure side of the manifold and is connected to a spring loaded piston. The piston extends under high pressure (spray trigger released) and retracts when spraying. At the opposite end of the arm is an allen screw and locknut. The allen screw bears on the microswitch arm to control the electric motor. When properly adjusted, the motor should turn off when the trigger is released. If it doesn't, loosen the locknut and adjust the allen screw slightly outwards toward the switch. Pull the trigger a few times and verify the motor starts up and shuts down when you release it. Tighten locknut.
Hope that helps.
Jul 11, 2014 | FAIP 1500 PSI Electric Power Washer
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
I tried to register my new Element Electonics 40" Model - ELDFT406. Says model # doesn't exist ? Also having trouble getting the tint setting.
so you shouldn\'t bother too much with it. I have the same model and it shuts itself off whenever it chooses to. I\'ve only had it since the 23rd of November, and it shut itself off after 2 days and maybe being on only 6 hours in those two days. It shut off the other day after 40 minutes. Read the reviews on Target\'s site, most people have issues.
On Facebook, the manufacturer said they would be adding this model to their site within a week, and that was around the 26th of November that they said that and it\'s still not on their site yet. I got mine at Target and I have 90 days to return it, so I\'m going to wait until TVs go on sale around the beginning of Feb and return it.
Dec 03, 2012 | Element Electronics HD LCD TV ELDFT404-B
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Burner doesn't shut off
What is the make and model number of the unit?
Nov 04, 2012 | Refrigerators
I need a user manual for FAIP-1500 Pressure Washer
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
Oct 23, 2012 | FAIP 1500 PSI Electric Power Washer
Bake does not work
most likely you have a bad ignitor,this is the first thing that goes,if it glows and doesn't ignite the flame within 40 seconds after it starts to glow the ignitor is still bad even though it glows orange.if it's a flat ignitor it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,if it's a round ignitor it takes 2.5 amps to fire it up.you don't have to shut the gas down,if it's a fairly new machine no electricity will go to the ignitor either if it's shut off but you can shut the breaker down if you want.the machines are not like the older machines where you lite it with a match,they are electronic ignition so check the ignitor first,if it doesn't glow at all you can check the ignitor for continuity with a meter.if you need any more help send the full model number off of the machine,open the bottom draw under the oven door,look on the frame,left or right side and you'll see a tag with the model number on it.good luck and happy new year.
Dec 30, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Reboot my h120 iriver
every time you turn on h120 (it will reboot)...update by itself...unless you get stuck while playing (freezes)...you will need a little needle/ safety pin to stick in the tiny hole on the bottom of the h120.......just tap it and take the pin out...player will shut down and start up by its self........feel free to rate the help
May 13, 2010 | iRiver iHP-120 MP3 Player
Code h120
I think you mean code H20, if so it means no water coming in, check water turned on ,check hose(s), check filter in inlet valve is clean, check water pressure is sufficient.
Plz rate my solution.
Thanks.
Dec 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Garden Logo
170 people viewed this question
Top FAIP Garden Experts
roeb
john h
Marvin
Marvin
Are you a FAIP Garden Expert? Answer questions, earn points and help others
