Question about Sony KV-32XBR200 32" TV
I have a Sony Wega KV-32XBR200 -- the picture seems to bow towards the top ; you can really tell when the image is letter boxed. Is there anyway to fix this in Service mode? I could not get the TV to enter service mode using the display+5+vol up + pwr trick... not sure if the service menu would be of much help either, since I looked at the technical manual and they say something about a v-bow & h-trap adjustments (which looks like my problem) ; they say adjust the 'y' magnets on the tube. Anyone done this? Suggestions?
Sony KV-40XBR700 40" CRT WEGA
I too would like to know the solution to this question...we are having the identical problem and Sony doesn't seem to know how to fix it. Although, the picture from the DVD player is perfect, the pictures for cable & video games are terrible. Very frustrating!
Aug 24, 2011 | Sony KV-40XBR700 40" TV
My tv is a sony xbr. somehow we got ourselves a black box (small) in the lower right hand corner. The remote doesn't have pip and we never used the pip. but i cannot get rid of this box. i tried to reset...
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Oct 21, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony trinitron picture bowed
YOU MAY A PINCUSHION PROBLEM...SEE A TECH....CUSTOMER CONTROLS WILL NOT CORRECT THIS !
Dec 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Red and blue shadows on my sony wega
hello it sound like convergance chips might be the trouble
shaun
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony KV-32hs510 Colors fouled up
same thing happend to me. KV-32HS420. first happened while my laptop was plugged in through SVideo port a month ago. hopefully the laptop did not cause it.
problem has progressively gotten worse (no laptop since). basically the picture turns reb/blue only for extended periods. dips back into normal picture, then back to red/blue.
Jan 02, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony wega tv problem
no,most of cases is only cause of loose contact.
Oct 18, 2007 | Sony KV-32XBR200 32" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
