Question about Tools & Hardware - Others
Palm sander won't turn on
My palm sander quit working in the middle of a project. I thought it might be clogged, so i took out the screws and cleaned the inside, including the coil, with a dry cloth. It still won't even turn on. What can I do to try and fix this?
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 104 Answers
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Posted on May 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: How do I replace the power cord for a makita palm
without knowing what the model number is you also have to remove the pad assembly and usually you will find some there if all removed you can GENTLY pry the cover halves apart. Go to Makitatools.com with you model number and you can download a breakdown for this tool.
Posted on Mar 16, 2010
Testimonial: "Thanks for this info. The Makita tool site is helpful as is your information. I found the schematics for my model BO4510. Wish me luck. JK"
  • 396 Answers
SOURCE: 1/4 palm Sander is not
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Posted on Jul 20, 2010
rowdy45176
  • 2176 Answers
SOURCE: How to take apart the Makita 1/4 palm sander in
you have to remove the platen on the bottom also, go to makitausa.com and you can download a parts explostion for this tool to see what I am talking about. If I have helped you would you please vote accordingly and thank you
Posted on Sep 11, 2011
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
Panasonic, model # PT-52LCX15
you might have more screws on the bottom i strongly suggest you be very carefull doing this the sreens are very delcate and cost lots of money
Nov 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
Skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Feb 23, 2012 | Tools & Hardware - Others
How to take apart the Makita 1/4 palm sander in order to replace the electrical cord? I have removed the four screws in the plastic part but it seems to have a snap section that isn't releasing. It...
Sep 08, 2011 | Makita Bo4556k Palm Grip Finishing Sander...
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Tools & Hardware - Others Logo
498 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
