Question about Nukote Nu-kote RF196 Black Refill Kit
My kit instructions do not cover HP black cartridge 96
I need to know which contacts to tape to reset the the printer after filling the cartridge
  • 3 Answers
1) Upper left, 2) then upper right, 3) then upper second right
Posted on May 27, 2009
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
The colour cartridge will print but the black one won't. Have replaced black cartridge but still won't print.
Clean electric contacts of the cartridge cradle with a tissue paper.
Go to support.hp.com, put your printer model and search for troubleshooting to get more instructions on solving this problem.
Nov 26, 2009 | HP DeskJet 5850 InkJet Printer
Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
Usually the refill kits come with instructions that cover many cartridges.
A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
Nov 11, 2009 | Lexmark X2500 All-In-One Printer
Ink and printer
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
HP 1220c problem
Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
Aug 28, 2007 | HP DeskJet 1220c InkJet Printer
210 people viewed this question
Top Nukote Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Nukote Office Equipment and Supply Expert? Answer questions, earn points and help others
