Question about Car Audio & Video
I have a california profile 600msx mono mosfet amp with power,but no sound.what could be causing that?
2 Suggested Answers
  • 631 Answers
SOURCE: whenever i wire 2 4 ohm svc subs the system just starts to pound real hard and its not like bass moving to music but just bass just moving up and down
It sounds like you have an open shield ground. To check the shield in your head unit, read through the following page.
Temporary Shield Ground Repair
Let me know if you have any other questions.
Posted on Aug 26, 2008
I have a California Profile 600 watt amp, I have multimeter and have power all the way to my 10
Power from ignition is setup to turn power On,
Check if +12V is available on "REM" terminal.
Check the speaker wirings , if speaker is connected to the
speaker output of the amp securely.
Oct 21, 2012 | Profile - California: 2 Channel 600W...
I have a 1000 w mono california amp is it 1oms safe or 2oms safe
It is always safer to use higher Ohms as it loads the Amplifier less.But you will get the rated power only when you connect the recommended impedance speakers. Eg: If the specs says 1000watts @ 2Ohms on connecting a 4Ohms speaker the Amplifier will only deliver 500watts.But will run cooler and is of course safer.
Aug 23, 2011 | Profile 600MSX Car Audio Amplifier
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
How do you get it out of cur mode
Hello whatup_132,
If the M605 fails and displays "CUR", it means that there is excessive current to the amp.
The most common causes for excessive current draw is operating the amp into a lower impedance than it is rated to handle, shorted speaker voice coil(s), and/or shorted or grounded speaker wires.
The amp can operate into a load no lower than 2ohms. First power everything off and disconnect the positive amp power lead temporarily (easist way is to just pull the fuse). At this point you should ONLY have the ground and remote connected. Reconnect positive (insert fuse) and turn on the vehicle ignition and your head unit. If the amp still displays the "CUR" error, the output MOSFET's are probably defective and the amp requires repair or replacement. If it powers up normally, reconnect the speaker wires until you locate the faulty one, and then correct whatever is causing it.
Hope this helps.
Jul 17, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Strange electric outburst
are your cables ran seperate? run the rca and remote wire opposite side of car where power wire is. rca and remote wire can pick up signal from elctric static from power wire.????
Jul 02, 2009 | Profile AP600 Car Audio Amplifier
Profile mono 1000watt amp
  1. safgegewgw
  2. gwggwegwgsdgderewgdgweg
  3. cdgegegewgegrgergweweewgewggwewegewg
Dec 13, 2008 | Profile 600MSX Car Audio Amplifier
Whenever i wire 2 4 ohm svc subs the system just starts to pound real hard and its not like bass moving to music but just bass just moving up and down
Aug 26, 2008 | Profile 600MSX Car Audio Amplifier
California 3600 mosfet discrete 3 ch amplifier 600 watts does not work
It sounds like it's going into protect. To be sure it's not the wiring, disconnect all speaker wires from it. If the light still goes out, check the DC voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier. If the voltage remains above 11 volts as the amp tries to power up, the output transistors are almost certainly shorted causing the amp to go into protect.
Nov 25, 2007 | Profile 600MSX Car Audio Amplifier
Blowing Fuses
If you disconnect the speaker wires from the amp and the fuse blows only after the remote voltage is applied (when the head unit is switched on), the output transistors are likely shorted.
Nov 14, 2006 | Profile 600MSX Car Audio Amplifier
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
