Question about Tiger Electronics Furby Pink white Electronic Furby
Furby model 59294 makes humming noise but does not work
I have replaced the batteries and it makes a ticking sound but nothing happens
My furby will not work?
The problem with your furby might be that it needs new batteries that was the problem with mine when that happened.
Jul 09, 2014 | Hasbro Interactive Furby for Windows
Furby Just Stopped working
Furbies tend to be stubborn and strong-willed. A search on the internet produced valuable information at www.instructables.com. So far, two have been revived. At the site given, look for push-start-a-comatose-furby. Good luck
Jan 13, 2014 | Tiger Electronics FURBY Interactive...
My furby lost his voice. He looks awake and moves his mouth but no sound. I have replaced batteries and restarted him, but he still can't make a sound
same just happened to my daughters furby boom. (Only bought yesterday). Something happened when using the app around the the change voice option in the game. Tried changing batteries and presing the re-set button to no effect?
Dec 27, 2010 | Tiger Electronics Furby Model 70 800
My furbys voice wont work.
You would have to take a look inside and make sure wires are ok. Could simply be a lose wire to the speaker sort of deal. Hope this helps
Mar 26, 2010 | Hasbro Interactive Furby for Windows
Found old furby toy w/carroaded batteries, brushed contacts, replaced, tryed reset,will not work.
then its broken, btw same thing happened to me!
i got one furby too but i tryed to change batteries, reset... nothing help
Feb 15, 2010 | Hasbro Interactive Furby for Windows
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Please help us start our Furby. It's never been used.
I just purchased an older Furby in a box too. It also wouldn't start up, even after I reset it several times and put in different batteries. Finally I just set it aside, with the batteries still installed, and it started up by itself about 30 minutes later. After it went to sleep I pushed on it's head to restart it, but it needed to be picked up and restarted by pushing the bottom a couple of times. I "fed" it until it "burped", and it seems pretty energetic now. :-)  Hope this works for you.
May 26, 2009 | Hasbro Interactive Furby for Windows
If you have installed new batteries and it still isn't working, It may have a burnt capacitor that needs replacement. You should also look for any broken or disconnected internal wires.
Here is a web link to the complete Furby users guide:
http://www.mimitchi.com/html/furbman.htm
May 13, 2009 | Hasbro Interactive Furby for Windows
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Tiger Electronics Furby Pink white Electronic Furby Logo
42 people viewed this question
Top Tiger Electronics Toys Experts
Jim Goldsmith
Jim Goldsmith
Tom Chichester
Are you a Tiger Electronics Toy Expert? Answer questions, earn points and help others
