Question about TP-LINK Computers & Internet
I forget my tp-link pw - TP-LINK Computers & Internet
How to log in
Hello, I'm not sure which type of wireless router that is but most router to log in have the same user and password for default.
User: admin
PW: admin
But first, you must be connected to the router via Wi-Fi or by LAN cable.
Follow these steps:
1. Make sure that you are connected to the router.
2. Find out what is your gateway, this is the IP address from the router. You can google by your router model or check the instructions, also most router have the IP address in the bottom of the router.
3. Open a web browser and type the router's IP address, click enter.
4. If everything is correct, a new window should be display prompting to input the user name and password, remember to try admin.
If admin doesn't work, then try:
User: root
PW: 1234
Hope this solve your problem. Good day.
Mar 11, 2014 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
I FORGET MY PASSWORD on tp link TL-WR841N
Most routers have a reset in the back. Hold it in till it cycles. This will clear all custom settings, and load defaults like new.
Dec 25, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Where can i find the wifi password on the modem
go to tplinklogin.net
then when use id = admin
and pw = admin
Oct 06, 2012 | TP-LINK TL-WR740N Router
Please get the personal-license(Ultra MP3) for my phone 7610 --- IMEI : 352273016296532
Remember that if you try more than 3 times your phones will be hardlocked and will be not possible to unlock remotely by code.
#pw+244222647402120+1#
#pw+636006333650602+2#
#pw+252552551255157+3#
#pw+340413141034712+4#
#pw+623146526351344+5#
#pw+047520343775426+6#
#pw+724177222431573+7#
Hope this helps.
Don't forget to rate this solution if it was helpful, thanks!
Jul 18, 2011 | Nokia 6600
TF3200 drivers for win 7
just select your operating system and dowload the program from here
http://www.driversbay.com/drivers/network-adapters/tp-link/tf-3200/
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | TP-LINK Computers & Internet
1100 nokia security code forget imei no.355655009910813
#pw+008793322754637+1#
#pw+328066646777004+2#
#pw+181774004034412+3#
#pw+957622774633161+4#
#pw+893421212201065+5#
#pw+198484412751220+6#
#pw+735960155406400+7#
users are successful using the code ending in +1#, so by all means, use this one first. Usually, if that is not successful, the #7's code works extremely well. This is because it is known as the Master unlock. However, depending on your service provider, your phone may only have a SP lock, which is easily removed with the +1#.
THANKYOU
Please do rate me if it works.
Dec 25, 2010 | Nokia 1110 Cellular Phone
I forget my security code my EMEI no is 353512027111951
Hi if you go to this website below, you can download a program called Worldunlocker, with this you can generate your OWN unlock code...
http://gsmevolution.com/WorldUnlock_v44_Setup.zip
An example of the output is below, i just guessed your settings....
Model: Nokia (1600 ) IMEI: 353512027111951 Network: 31038000
#pw+059 373 476 630 664+1# #pw+998 672 711 563 060+2# #pw+358 576 774 542 360+3# #pw+993 932 512 036 125+4# #pw+489 787 307 674 172+5# #pw+439 387 251 670 574+6# #pw+988 662 102 553 656+7
Aug 18, 2010 | Nokia 1650 Cell Phone
Forget my personal lock code
#pw+106914725471323+1#
#pw+138514753677122+2#
#pw+497597111527102+3#
#pw+798100614623017+4#
#pw+283595606167200+5#
#pw+057393070555703+6#
#pw+195924610341532+7#
Nov 16, 2008 | Nokia 6610
Unlock Code
hi sir.
lt surely unlock your phone that s 100% sure...
here are the codes
IMEI: # 352268/01/527091/8
Network: 27203000
#pw+198 936 432 9+1#
Security Code: 59025
Network: 27203000
#pw+040 775 944 3+1#
IMEI: 352066024767241
Network: 27203000
#pw+042 563 077 007 461+1#
#pw+016 323 441 435 123+2#
#pw+418 507 340 617 000+3#
#pw+074 073 506 212 577+4#
#pw+905 012 735 332 515+5#
#pw+113 404 347 146 701+6#
#pw+989 062 614 762 261+7#
it fix the problem.. don't forget to fix..
Sep 03, 2008 | Nokia 6101 Cellular Phone
Nokia N73
hi, can you help me to reset the lock code of my N73 cell phone, i forget the lock code
here is my imei # 358973013593229
Jan 05, 2008 | Nokia 1600 Cellular Phone
Computers & Internet Logo
220 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
